Toon app: Buienradar
yjb
Re: Toon app: Buienradar
Post by yjb »
For whatever reason KNMI station Berkhout (6249) never returns a value for air pressure (ld). This results in NaN hPa on the screen.
As I'm not really familiar with java I just made a quick 'n dirty fix:
 diff buienradar*
--- buienradar.js
+++ buienradar.js.org
@@ -103,9 +103,6 @@
 function formatLuchtdruk(ld, humidity) {
-       if (isNaN(ld)) {
-       ld = 0;
        return i18n.number(ld, 0, i18n.general_rounding, 1) + " hPa; lv: " + humidity + " %";
Might be nicer to remove the reference to a value completely if a value is NaN (not only for air pressure)
Thanks for the tip, on my todo list now...
Blacky's Boss
Post by Blacky's Boss »
I just noticed that the map is gone in the rain-location settings.
And the prediction seems to be a bit off, comparing to the android app "Buienalarm"
Blacky's Boss wrote:I just noticed that the map is gone in the rain-location settings.
hmmm, this is the current response from google when retrieving the map:
"The Google Maps Platform server rejected your request. You must use an API key to authenticate each request to Google Maps Platform APIs. For additional information, please refer to http://g.co/dev/maps-no-account"
Seems that I need to pay to continue using the services (although there is a free number of calls each month which is more than sufficient).
I will look into it later this month (after the calendar app has got a few updates)
I looked into this and cannot get it to work on Toon alone (due to the lack of a proper browser) with a purchased api key.
Alternatively I could host a webserver as intermediate but don't feel it's worth the trouble.
I will remove this map and provide instruction how to get your exact coordinates from a browser on another device.
I will include this in the next version which should also be compatible with firmware 5.0.0 (takes a while)
Post by TheHogNL »
You could also try this:
curl -Nks https://ipinfo.io/json
or
curl -Nks https://get.geojs.io/v1/ip/geo.json
both are free, and getting very close to my home (neighbouring cities, but close enough for weather).
You could use that as a default setting when started for the first time.
this isn't good enough, for the rain prediction tile you need the nearest coordinates to your house in two decimals (which gives you a square of a few hundreds meters wide.
Visit maps.google.nl, zoom in to your location and click on your house on the map. You will get a popup window with the longitude/latitude coordinates.
Write down these coordinates (rounded to two decimals) and enter these into the buienradar config screen.
Rounding to two decimals because this is the lowest resolution in which the buienradar website provides the rain prediction datasets
Post by TheHogNL »
Another option could be this:
This is a simple javascript running on the toon which, when browsed to from your mobile, asks the geo location of the phone and prints it on screen (could be then automatically entered in buienradar app ofcourse).
Only need to enable https support on the toon for this (as this javascript doesn't work on http only).
Owh darn.. now you all know where I am...
hi all,
the new version 8.4.1 is available on ToonStore.
Changelog:
- installer is now firmware 5 compatible, it will patch the app on the fly when installed on firmware 5.
- removed the google map on the detailed location configuration screen. Manually need to enter your lat/lon coordinates now
this is due to the new licensing model of google maps which cannot be supported on Toon without a browser
Strijker
Post by Strijker »
For some time now, my Toon shows some rain to be expected while there realy isn't any rain forecasted. I feel it to be roughly at the same time showing the same rain expectancy pattern every day; asif some buffered data is replayed.. Yesterday I updated to 8.4.1. hoping to fix this 'glitch' but this morning I saw it's still there..
but the radar is showing nothing..
Any clue?
the source of this rain prediction data is http://gadgets.buienradar.nl/data/raint ... 1&lon=4.52 (example)
The latitude (breedtegraad) and longitude(lengtegraad) are taken from the two files selectedLatitude.txt and selectedLongitude.txt.
Can you check whether these two last files exist in /qmf/qml/apps/buienradar ?
If not, click on the rain tile, press 'locatie' in the top tight corner and set these two coordinates for your location.
If that all looks fine, you can check the gadgets url manually with your coordinates to see if that delivers different data (the first three digits om each line contains the rain data).
Let me know if this all looks fine and you still see something different on Toon compared to the gadget file.
Strijker
Post by Strijker »
Yes, those files exist and contains valid data which in turn delivers a table from buienradar.
Thank you for the link, I will check it the moment I catch a false prediction graph again.
How frequent is this data being polled?
Strijker wrote:Yes, those files exist and contains valid data which in turn delivers a table from buienradar.
every 5 minutes
imdos
Post by imdos »
Might be a silly question and even related to the ToonStore; but I have two entries in my toon (4.22.7) on /qmf/qml/apps/
buienradar
buienradar-8.4.1
And inside buienradar is a symbolic link to buienradar-8.4.1. The same applies to boilerstatus-1.0.6. However the other apps I have installed:
  • calendar
    fileinfo
    toonstore
    wastecollection
Provide a symlink on the top level e.g. /qmf/qml/apps/wastecollection => /HCBv2/qml/apps/wastecollection-4.19
I don't know which one is more correct without spending too much time on the code. I hope you could elaborate on it.
Furthermore I have added the two files: selectedLatitude.txt and selectedLongitude.txt with only the coordinates like 50.03 and 4.03 or something; since it doesn't work properly from the qt-gui.
Lastly I found that the weather report is off and found an empty weerstation.txt file in the buienradar folder.
When you look carefully, you will see that the directory entry without version number is a symbolic link to the directory entry with version number. We have designed all toonstore apps to be installed in this way, so you can immediately tell from the qmf/qml/apps/ directory which versions of an app you are using.
In older firmwares /HCBv2 was the top level directory for the toon-specific software. In later versions (as of 4.10 or thereabouts) this has been changed to /qmf. The links to /HCBv2 still exist in some apps.
Not sure about your weather issue.
