Very nice installation!EchoNL wrote:Received all the parts and installed everything. Really easy install . I downloaded a bracket from the thingiverse website for the sensus 620 and 3d printed it. Fits perfect!
Keep up the good work!
Toon App: Water
- Advanced Member
Re: Toon App: Water
Re: Toon App: Water
Did you setup the right address for the router and sub domain?RoelToonz wrote:Hello
I have flashed the wemos like the subscribtion, i can connect it with the phone set up my wifi but than at point 7 i cant klik on the link so i set a free static ip adres and confirmed it, but i cant find the wemos ip adres in my network so i think i wil not connect to my network. Please help
- Advanced Member
Re: Toon App: Water
After selecting wifi network, fill in your wifi password, static ip, static gateway and subnet. Click save.
Select your wifi network (the one you have selected in the setup) and browse to the static ip adress you have selected (or http://esp-toonwater.local). If you cannot find the adress, power off and power on the Wemos again.
If you are using a old, previous used Wemos, flash the blanco 4MB image first.
Re: Toon App: Water
Snug fit for the Wemos D1 mini. Project finished. Both things printed from thingiverse.
- Toon Water
- Toon Water Meter.jpg (168.16 KiB) Viewed 3496 times
- Advanced Member
Re: Toon App: Water
Nice job! I am awaiting for the sensors to arrive and then i can send the first completed devices out.
- Member
Re: Toon App: Water
Finally received my sensor from Ali today. I made a nice holder from plexiglass.
Software and hardware seems to be in order, because if I wave a piece of metal in front of the sensor, the counter in the Wemos web interface goes up.
Problem is that wherever I position the sensor, it does not detect the turning wheel in the watermeter yet.
I probably need to grind the blue tip of the sensor. Haven’t done that yet. How much can I grind off? In the start of this topic 1mm is mentioned. Seems like a lot. Is there risk of grinding too much off?
Re: Toon App: Water
Mine works fine without grinding, did you check the detection distance with the piece of metal? And it needs to be aligned off center to work.
- Member
Re: Toon App: Water
My sensor only detects metal when it’s within 4-5mm distance.
Yes, the hole is at the right place, but I also checked different positions on the watermeter manually but nothing is detected.
- Advanced Member
Re: Toon App: Water
Did jou drill the hole through the plexiglas so the sensor is in contact with the meter itseld? If so, start to grind a bit of the tip of the sensor bit-by bit. I have a sensor wich has conpletely lost the blue plastic and is still working. I think the plastic is to closes the sensor for water.Arnout2000 wrote:My sensor only detects metal when it’s within 4-5mm distance.
- Member
Re: Toon App: Water
I have started grinding. See the photo of the result. When moving the sensor manually over de meter it now detects the coil so that is good News! I can start mounting now.
Yes, the sensor hangs beneath the plexiglass so the tip directly touches the plastic cover of the meter.
- 32798317-DEFA-4B61-9650-F1FAC1BAD2F8.jpeg (26.55 KiB) Viewed 3417 times
- Advanced Member
Re: Toon App: Water
Yes, it is just a plastic cap to close the sensor. Best is to mount it with water flowing.. so open one of the water tap points.
- Member
Re: Toon App: Water
Installation complete. Works like a charm.
I only had to enter the current value of the watermeter in the ESP interface. If I enter the value on the Toon the value becomes weird. Is that a know bug?
- 8007ACF8-D6C3-4452-9229-2F4411365245.jpeg (67.55 KiB) Viewed 3412 times
Re: Toon App: Water
You should enter 231562 and not 231,562 or 231.562
- Member
Re: Toon App: Water
Yes that’s what I did. The same applies for the ESP interface. No points or commas.Jasper wrote:You should enter 231562 and not 231,562 or 231.562
Re: Toon App: Water
You mean first days use? That's normal because it has a previous value which was reported earlier and I cannot tell if that's fixed yet. You should wait for oepie loepie then to confirm.
