Toon app: Kalender
Re: Toon app: Kalender
this is not an official json format, you can put it al on one row, you should not use a comma to start a new line.
you are also missing the closing quotes after the third calendar url.
example:
   "DimTileExtended",
    "Yes",
must be:
   "DimTileExtended":"Yes",
or if you prefer:
   "DimTileExtended"
    "Yes",
jazzper
Post by jazzper »
Toonz wrote:this is not an official json format, you can put it al on one row, you should not use a comma to start a new line.
example:
   "DimTileExtended",
    "Yes",
must be:
or if you prefer:
   "DimTileExtended"
    "Yes",
Ahhh thanks for a push in the right direction!
Verstuurd vanaf mijn MI 3W met Tapatalk
Ridder
Post by Ridder »
Just got a rooted Toon and installed the calendar app from the ToonStore.
I only have some holidays now on Toon.
Is it possible to import my own calendar without coding....just enter some url in the app???
Maybe this has been answered before....but I couldn't see the trees through the forest :D
eelcova
Post by eelcova »
I have replaced the Holiday calendar with my personal ics-url in my userSettings.json file, but the app still shows Holiday calendar, even after reboot.
What am I doing wrong?
markismus
Re: Toon app: Kalender OpenSourced
Post by markismus »
I finally got around to making the Toon Kalendar fully opensourced. It's now working independent of Google and iCloud and whatnot.
Steps to get it working:
1.- I've defined a local path in the app, e.g. "file:///mnt/data/tsc/myCalendarRadicale.ics".
2.- I've installed Radicale on my server and made a calendar and logged in via the webinterface to get the url to the calendar.
3.- I've made a simple script to retrieve the calendar file from a WebCal server, e.g. /root/getRadicale.sh:
rm /mnt/data/tsc/myCalendarRadicale.ics;
curl --user 'Username:Password' 'url' --anyauth > /mnt/data/tsc/myCalendarRadicale.ics
and put in the /root directory and made it executable with
chmod +a /root/getRadicale.sh
4.- I've installed cron and made a 10 minute job to sync the calendar file: (crontab uses VI, so use 'i' for insert text and 'ZZ' for saving)
# /root/update_rooted -o
# opkg install cron
# crontab -e
>*/10 * * * * /root/getRadicale.sh
Now I am able to make an new event on my Android Phone in the Etar app, sync it with DAVx5 and have it appear in the Toon Kalender in 10 minutes.
Another approach
I also tried to change the url in the Kalender app to include the username and password. WebDAV seems to use the format
http://username/password/server:port/.....
However, it didn't work.
A lot of work
Getting everything up and running took rather a lot of work. To make it easier for others to get it running, it would be nice if you could for instance let the script execute the curl-command and follow it with a file:///... internally.
Nice work, but 'too much' for the average user I think :) .
Not sure what you ask me to do by the way in the Toon app itself.
Using crontab to schedule your script is a good solution (you cannot simply run scripts from the Toon QML application).
In the app settings you can refer to your own downloaded calendar file, that is already working fine today.
version 1.1.12 of the Kalender app is available in the ToonStore.
Changelog:
- an option has been added to the settings screen to set the refresh cycle for the calendar in minutes (min 10, default setting is 60 mins).
Calendar will be refreshed after the end of the current appointment also.
N.B. Old logic was that the calendar was refreshed every 6 hours and at the end of the active appointment (whichever is sooner).
Kind regardz,
markismus
Post by markismus »
What I would like to do, but can't since I mostly program Perl nowadays, is recognize a given http-string as a curl-command. Execute that curl-command in the shell. Recognize the name of file generated or append it if it's missing and generate a file-string to read it into the Kalender app.
E.g. in Perl:
if( $String=~ m~^curl~ ){
    if( $String =~ m~>(?<ics-filename>.+$){
        $ice-filename = $+{ics-filename};
        $command = $String;
    else{
        $ics-filename = "/mnt/data/tsc/retrieved_calendar.ics";
        $command = $String . ">$ics-filename";
    unlink ($ics-filename);
    `$command`;
    $String = "file:///$ics-filename";
markismus
Post by markismus »
I realize that having the shell execute a command is harder is Javascript. Apparently, the question has been raised before: execSync with the option shell.
However, I wonder whether this is implemented by Quby's version of Javascript.
Isn't execSync part of Node.js? This isn't supported on Toon (too limited resources).
With the new app version above you can keep running your script with crontab and the app will pick it up within 10 minutes.
Isn't that close enough to what you want to achieve?
markismus wrote: Another approach
shouldn't this be: http://username:password@server:port/.....
markismus
Post by markismus »
Yes! Works!
version 1.1.14 is available in the ToonStore.
Changelog:
- long appointment titles are now truncated on the tile (to stay within the tile limits)
Kind regardz,
version 1.1.5 will be available in the ToonStore shortly.
Changelog:
- in the settings screen you can easily add and remove public calendars from a github repository (currently a few Formula1 calendars are added).
If you want other public calendars to be added , just drop the link to the ICS file here or send me a PM with the link.
Ideas: calendars for the Olympics or other sports games.....
I can instantly add these to the github repository (no new app release needed for this).
Kind regardz,
gert848
Post by gert848 »
Thanks Toonz,
Nice work when i have new calenders i let you know.
Greats Gert :)
