Hope you find the time to support Midden-Drenthe....Toonz wrote:This is a bit of tough one. For the time being I can't support middendrenthe.
Does anyone know how to get the dates into a waste.txt?
All info about waste.txt is included in the first post of this topic.jblokzijl wrote:Hope you find the time to support Midden-Drenthe....Toonz wrote:This is a bit of tough one. For the time being I can't support middendrenthe.
can you PM me your zipcode?Martijne wrote:I'm having issues with the afvalwijzer app for area-afval.nl (my region). I have configured 'Afvalverwerker' number 25 and set my 'Postcode' and 'Huisnummer'.
I have dowloaded the .ics file from https://www.area-afval.nl/ and saved it on my Toon as /root/waste/waste_calendar.ics.
This results are shown in the pictures below. The dates are correct, but no info about the type of waste. Can this be fixed?
Hi Toonz,Toonz wrote:Hi all,
version 4.44 is available in the ToonStore.
Changelog:
- fix for mijnafvalwijzer.nl (provider "1"). They are not supporting the JSON interface anymore,
falling back to scraping the HTML page
Kind regardz,
can you try a restart of the gui and wait 6 minutes?If that doesn't help, can you PM'me your zipcode?madpatrick wrote:Hi Toonz,Toonz wrote:Hi all,
Changelog:
Kind regardz,
Thanks for the fast update, but it stil not working for me.
How can i check things ?
Now it is working again. Great job !Toonz wrote:Apologies all, forgot to mention you have to change the waste provider from "1" (mijnafvalwijzer json) to "31" (mijnafvalwijzer html).
Yes I saw it now also. Too bad!Toonz wrote:The new mijnafvalwijzer.nl api requires an api key. So far the company behind mijnafvalwijzer.nl is not willing to provide a valid api-key and neither allows us to use an existing api-key which we can get by reverse engineering their app.
Till that is resolved I will keep the html option active in our app which doesn't matter in the end for us.
