Toon app: Afvalwijzer
hdok
Re: Toon app: Afvalwijzer
Post by hdok »
Don't know exactly when this started happening but I just get an empty list when retrieving information for Venlo. This worked fine before. Is there a log or anything that I can look into to see what happens?
Not really, probably means the website of your provider isn't working or they changed it.
Which waste collector are you using?
hdok
Post by hdok »
Toonz wrote:Which waste collector are you using?
27 venlo.nl
Link to current site: https://www.venlo.nl/trash-removal-calendar/ical/PPPP/N
Rudolf
Post by Rudolf »
Thermostat Mod now optional, nice! Thnx. :D
27 venlo.nl
seems to work fine, at least today.....(I tested with 5914LW, housenr 338)
hdok
Post by hdok »
That same address does not work for me :-(
Could it be that the venlo.nl started forcing HTTPS and that that does not work for my toon but it does for yours?
wget http://www.venlo.nl/trash-removal-calendar/ical/5914LW/338
--2018-11-18 22:10:33--  http://www.venlo.nl/trash-removal-calendar/ical/5914LW/338
Resolving www.venlo.nl... 83.217.76.213, 2a00:1c98:10:25::213
Connecting to www.venlo.nl|83.217.76.213|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://www.venlo.nl/trash-removal-calendar/ical/5914LW/338 [following]
--2018-11-18 22:10:34--  https://www.venlo.nl/trash-removal-calendar/ical/5914LW/338
Connecting to www.venlo.nl|83.217.76.213|:443... connected.
Unable to establish SSL connection.
Using the app store I can install other stuff just fine. I can reach other site from toon:
ping www.google.com
PING www.google.com (172.217.17.100): 56 data bytes
64 bytes from 172.217.17.100: seq=0 ttl=56 time=13.482 ms
64 bytes from 172.217.17.100: seq=1 ttl=56 time=24.430 ms
64 bytes from 172.217.17.100: seq=2 ttl=56 time=20.735 ms
I have removed and reinstalled WasteCollection (from the Toon store), apparently without errors:
>> Welcome to the ToonStore updater,
>> brought to you by the Toonroot Software Collective (TSC)
>> 2018-11-18 23:22:52 +0100 (pid 8433) _opkg.qb2-uni-9.9.99.script.sh qb2 uni 9.9.99 prepare
>> 2018-11-18 23:22:52 +0100 (pid 8433), status = preparing
>> Firmware version: 4.22.7, build 1273, rev 0.
>> System load     : 1.28
>> Free RAM        : 5168K
>> Flushing file system buffers and cache ...
>> Free RAM now    : 10844K
>> Hotfix for writing System Time to RTC
Hardware Clock before: Sun Nov 18 22:22:54 2018  0.000000 seconds
Hardware Clock after : Sun Nov 18 22:22:54 2018  0.000000 seconds
rm: can't remove '/var/lib/opkg/tsc*': No such file or directory
>> Installing wastecollection-4.8
>> Extracting packages from the following repo('s):
src/gz tsc1 http://files.domoticaforum.eu/uploads/Toon/apps/wastecollection-4.8
/mnt/data/update/_opkg.qb2-uni-9.9.99.script.sh: line 568: echo>> dependencies found: wget-1.12 cron-3.0 tsc-certificates-1.0.1: not found
src/gz tsc2 http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/wget-1.12
src/gz tsc3 http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/cron-3.0
src/gz tsc4 http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/tsc-certificates-1.0.1
>> configured opkg feeds:
>> opkg update
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/wastecollection-4.8/Packages.gz.
Inflating http://files.domoticaforum.eu/uploads/Toon/apps/wastecollection-4.8/Packages.gz.
Updated list of available packages in /var/lib/opkg/tsc1.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/wastecollection-4.8/Packages.sig.
Signature check passed.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/wget-1.12/Packages.gz.
Inflating http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/wget-1.12/Packages.gz.
Updated list of available packages in /var/lib/opkg/tsc2.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/wget-1.12/Packages.sig.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/cron-3.0/Packages.gz.
Inflating http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/cron-3.0/Packages.gz.
Updated list of available packages in /var/lib/opkg/tsc3.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/cron-3.0/Packages.sig.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/tsc-certificates-1.0.1/Packages.gz.
Inflating http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/tsc-certificates-1.0.1/Packages.gz.
Updated list of available packages in /var/lib/opkg/tsc4.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/tsc-certificates-1.0.1/Packages.sig.
>> Package cache: /mnt/data/update
>> opkg --cache /mnt/data/update install --download-only wastecollection
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/wastecollection-4.8/wastecollection_4.8-r0_qb2.ipk.
>> opkg --cache /mnt/data/update install --download-only wget
Package wget (1.12-r8.3) installed in root is up to date.
>> opkg --cache /mnt/data/update install --download-only cron
Package cron (3.0pl1-r8) installed in root is up to date.
>> opkg --cache /mnt/data/update install --download-only tsc-certificates
Package tsc-certificates (1.0.1-r0) installed in root is up to date.
>> downloaded:
80.0K   total
>> dropboxMessage wastecollection-4.8BRBRBekijk de berichten voor deze software voor informatie over eventuele configuratie.
>> no packages to be removed
>> 2018-11-18 23:23:03 +0100 (pid 8433), status = prepared
>> 2018-11-18 23:23:05 +0100 (pid 8608), status = execute
>> 2018-11-18 23:23:05 +0100 (pid 8608), status = executing
>> opkg --cache /mnt/data/update install wget
>> opkg --cache /mnt/data/update install cron
>> opkg --cache /mnt/data/update install tsc-certificates
>> opkg --cache /mnt/data/update install wastecollection
Installing wastecollection (4.8-r0) to root...
Copying /mnt/data/update/wastecollection_4.8-r0_qb2.ipk.
Running preinstall for wastecollection-4.8
Older installation detected.
Backing up previous settings ...
Running postinstall on /HCBv2/qml/qb/base/Globals.qml
grep: /HCBv2/qml/qb/base/Globals.qml: No such file or directory
Adding wastecollection to Globals.qml
sed: /HCBv2/qml/qb/base/Globals.qml: No such file or directory
running firmware version 4 - 22 - 7
Creating symbolic link /HCBv2/qml/apps/wastecollection to /HCBv2/qml/apps/wastecollection-4.8
Posting message
Configuring wastecollection.
>> deleting /tmp/dependencies_to_install.txt
>> deleting /tmp/packages_to_install.txt
>> reinstating cache handling (default 0)
>> deleting /tmp/install_status
>> deleting all in /mnt/data/update
>> (this may give some errors, no problem here ...)
>> 2018-11-18 23:23:13 +0100 (pid 8608), status = executed
>> Restarting qt-gui and hcb_config ...
Anything else I could check?
hdok wrote:That same address does not work for me :-(
hmm, I tested on a Toon 2 only, could be that that one has newer ssl root certificates than Toon 1.
Will have a look later this week (first Germany - Holland :-) )
I probably need to update the tsc-certificates package with updated root certificates.
to be continued......
Kind regardz,
How does your folder /etc/ssl/certs look like?
hdok
Post by hdok »
/etc/ssl/certs# ls
Comodo_RSA_CA-01-2038-Quby_Countly-hcb_bxtproxy.pem
DigiCert_GlobalRoot_CA-11-2031-Buienradar-qt-gui.pem
DigiCert_Global_Root_CA-meethue-hdrv_hue.pem
DigiCert_Global_Root_CA.pem
GeoTrust_Global_CA-05-2022-Myfox_API-hdrv_hue.pem
GlobalSign_Root_CA.pem
GovernmentoftheNetherlands_G3.pem
Starfield_Services_CA-G2-12-2037-dpc_qutility-hcb_bxtproxy.pem
VeriSign_Class_3_Public_Primary_Certification_Authority_-_G5.pem
ca-certificates.crt
ca-certificates.crt.tsc_backup
comodo-rsa-domain-validation-sha-2-w-root.ca-bundle.pem
eneco.pem
hdok
Post by hdok »
hdok wrote:
/etc/ssl/certs# ls
This is actually the CA that venlo.nl is using so , I assume the problem lies elsewhere...
can you check if the GovernmentoftheNetherlands certificate is included in the file ca-certificates.crt?
hdok
Post by hdok »
:/etc/ssl/certs# grep MIIFdDCCA1ygAwIBAgIEAJiiOTANBgkqhkiG9w0BAQsFADBaMQswCQYDVQQGEwJO ca-certificates.crt
I think that is a yes
Is other https functionality working, like wget https://xml.buienradar.nl?
hdok
Post by hdok »
--2018-11-24 14:39:26--  https://xml.buienradar.nl/
Resolving xml.buienradar.nl... 95.101.2.90, 95.101.2.78, 2a02:26f0:7b:389::5ddd, ...
Connecting to xml.buienradar.nl|95.101.2.90|:443... connected.
OpenSSL: error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol
That does not work, yet the buienradar app does work.
and I have installed the tsc package
slowly running out of options. Which version of wget do you have installed?
Check via 'opkg list-installed'
