Page 28 of 84
Re: Toon app: Afvalwijzer
Posted: Mon Apr 09, 2018 4:31 pm
by Toonz
Version 3.7 available on ToonStore.
Changelog version 3.7:
- avalex.nl implemented (waste provider 24, enter ical calendar id in settings screen)
no need to upgrade if using another waste provider.
Kind regards,
Posted: Mon Apr 09, 2018 7:13 pm
by glsf91
Toonz wrote:
As soon as someone has a good solution to make http POST calls from Toon I am more than happy to integrate that in the app.
Curl can do POST calls. Can you not use curl?
Don't know if this can integrate with your app.
Posted: Mon Apr 09, 2018 7:39 pm
by Toonz
If it works you can use it together with a cron job, but it is to be seen case by case whether the http(s) response is usable.
Posted: Wed Apr 11, 2018 9:02 pm
by newwolf
Could you please add "Area reiniging" ?
https://www.area-afval.nl/voor-bewoners ... alkalender
Postcode: 7861aa
Posted: Thu Apr 12, 2018 12:10 am
by Toonz
Yes. You will need to manually download the ical file once a year and copy it over to Toon.
Will do in next release....
Posted: Sat Apr 14, 2018 2:58 pm
by Toonz
Afvalwijzer 3.8 is available on ToonStore.
Changelog version 3.8:
- area-afval.nl implemented (waste provider 25, download ical from their website and copy the file to Toon as /root/waste/waste_calendar.ics
The file contains the full year calendar, so repeat the download once a year when next year's calendar is published
No need to upgrade for existing users.
Posted: Sun Apr 15, 2018 11:15 am
by newwolf
Thanks Toonz
Posted: Mon Apr 16, 2018 4:45 pm
by jnieuw
Suddenly, since an (automatic?) reboot last night, afvalkalender (v3.
isn't displaying anymore.
Downloads are from a local http server, that can be pinged/and the file can be downloaded using wget. Also the file wasteDates.txt is available in /var/volatile/tmp and contains data.
btw. buienradar (v8.3.4) is also not working anymore. (no data displayed, but same issue: ping is working, don't know where the files are stored),
I've set ToonStore to automaticly update the apps, so I think it rebooted toon last night.
Posted: Mon Apr 16, 2018 6:38 pm
by Toonz
Weird, buienradar is not storing weather data, it is retrieved every 5 minutes or so from
https://xml.buienradar.nl/.
Could be that internet access is broken from Toon or that the needed CA certificates are not available on Toon anymore.
You could try to remove the waste collection app and the buienradar app through ToonStore and install again afterwards.
Posted: Mon Apr 16, 2018 6:40 pm
by jnieuw
Are there any logs somewhere I can check?
Posted: Mon Apr 16, 2018 6:52 pm
by jnieuw
Ok, when I do this:
I get:
--2018-04-16 16:49:59-- https://xml.buienradar.nl/
Resolving xml.buienradar.nl... 104.93.83.24, 104.93.83.81, 2a02:26f0:fe:29d::5ddd, ...
Connecting to xml.buienradar.nl|104.93.83.24|:443... connected.
OpenSSL: error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol
Unable to establish SSL connection.
Edit:
Curl works.
Posted: Mon Apr 16, 2018 7:14 pm
by jnieuw
Removed buienradar, rebooted, reinstalled, cannot even select weatherstation(?)
Posted: Mon Apr 16, 2018 10:54 pm
by Toonz
that's because it cannot read the
https://xml.buienradar.xml file. At first retrieval it collects all available weatherstations and populates the selections screen.
Have you recently upgraded the firmware? I suspect your CA certificates repository has screwed up somehow, blocking SSL access to those sites.
Can you reinstall the certificates again via the attached ipk? No need to restart the gui afterwards, should work rightaway.
Posted: Tue Apr 17, 2018 6:03 am
by BOverdevest
Werking fine! Thanks
Sent from my iPhone using Tapatalk
Posted: Tue Apr 17, 2018 8:27 am
by jnieuw
Reinstalled the certificates, same problem (cannot change weerstation and no data)
Rebooted, same problem.
Removed buienradar, rebooted, reinstalled buienrader (using ToonStore), same problem.
Afvalkalender is using HTTP access b.t.w. so no certificates there.
Also the file wastedates.txt is there, but somehow not read by afvalkalender. Can it be a permission or corrupted file problem?
