Page 1 of 22
Toon app: Buienradar
Posted: Thu May 25, 2017 3:42 pm
by Toonz
This is the continuation of a series of other posts on the buienradar app, in another thread. It starts here:
viewtopic.php?f=87&t=11234&start=45#p81263
Posts in that thread are mixed with other subjects, this new thread should stick to buienradar only.
HI all,
a new release of the buienradar app after feedback from the user panel (my wife):
Changelog:
- added sunrise/sunset times to the detail screen
- clicking on the weather forecast text box on the details screen now opens a new full screen weather forecast.
the text box on the details screen is still scrollable but this is not working very user friendly
N.B. keep the three files ("selected...txt) in your buienradar app folder on toon with your location data.
Idea for a further change: replace the weather icon on the buienradar tile with the rain forecast graph for the next two hours if rain is expected.
This will save a tile position for the rain forecast. Makes sense?
EDIT: attachment removed. See next post
Re: Toon app: Buienradar
Posted: Thu May 25, 2017 4:38 pm
by Toonz
a small bug fix update:
Changelog:
- fixed an error where after reading the default lon/lat coordinates from file at startup, the exact location of the yellow markers on the big and small buienradar image screens where not updated
EDIT: attachment removed. Buienradar now available via ToonStore
Regardz,
Posted: Sat Jun 03, 2017 8:59 pm
by Toonz
apologies for my lousy version control.
In the last few releases 5 lines were missing from BuienradarApp.qm at line 255:
if (BuienradarJS.determineNight (timeStr, zonopkomst, zononder))
screenStateController.backLightValueScreenDimmed = 10;
else
screenStateController.backLightValueScreenDimmed = 30;
screenStateController.notifyChangeOfSettings();
These lines reduces the brightness value in dim state to 10 automatically after sunset and increase again to 30 after sunrise.
I personally find at very convenient. If you don't think this is important you can either stick to the last release or comment out these lines.
N.B. Last change was to add a full screen weather forecast (text only) when clicking on the weather forecast text in the detail screen for easier reading.
The big screen is scrollable as well, so all text is now easily readable.
Posted: Thu Jun 15, 2017 10:11 pm
by Toonz
Happy to give the next release of the buienradar app.
On the main radarimage screen (accessible via the systray icon) you can also select the 'pollenradar', 'muggenradar' and 'BBQ radar' images showing the predictions for the next 5 days.
Default option is always the standard buienradar images.
Changelog:
8.0
- added Mosquitoradar, BBQ radar and pollenradar to the main Buienradar screen (accessible via the systray icon)
- added this changelog
I also added a full Changelog.txt in the zipfile.
N.B. In the BuienradarApp.Qml at line 253-257 is code active which controls the brightness setting of the screen in dimstate based on sunrise/sunset times. If you don't want that remove those lines or comment out.
EDIT: I removed version 8 for now because of two bugs:
- the icon marker was not placed correctly because I moved the map but not the marker
- the rain tile was reading testdata instead of actual data
Corrected version will be posted later today.
Apologies for the inconvenience.
Posted: Thu Jun 15, 2017 11:06 pm
by marcelr
Hi Toonz,
i just had a look at the new buienradar. Looks good, although now my location in the big radar screen has moved a bit far to the east. (halfway between the Dutch border and Poland). Not sure what it is. The four options for all kinds of radars are really cool.
Posted: Fri Jun 16, 2017 8:29 pm
by Toonz
Happy to give the next release of the buienradar app (Thanks to Marcelr for testing).
Changelog:
8.0.1
- corected a bug where the small yellow marker on the big radarimage map was dislocated (bug was introduced in version 8 by moving the map but not the marker)
- yellow marker now suppressed when viewing muggenradar, pollenradar or BBQ radar on big radarscreen
8.0
EDIT: Removed attachment, later version below....
Posted: Mon Jun 19, 2017 9:23 pm
by Toonz
latest addition: additional static screens as provided by buienradar.
Changelog:
8.0.3
-added the following NL - maps to the big radarimage screen accessible via de systray (button "Extra schermen")
minimum temperature today
maximum temperature today
actual temperature
actual windforce and direction
minimum ground temperature today (convenient during winter)
Posted: Sat Jul 01, 2017 11:56 am
by Toonz
a small cosmetic update for Buienradar to update some screen titles. If you are not bothered by that there is no need to install this version.
Changelog
8.0.4
-cosmetic change: updated screen titles for minimum and maximum temperature in the extra radar screens
-teaser: added the version.txt file for an exiting future development coming soon (or not, depending on the progress we make)
Posted: Sat Aug 05, 2017 10:21 pm
by Toonz
new Buienradar app release.
Changelog:
8.0.6
- rain prediction data feed URL did change at the buienradar site (for the next 2 hour rain prediction tile per lat/lon coordinates)
8.0.5
- actual temperature saved after each update to file:///var/volatile/tmp/actualBuienradarTemp.txt for use in the TemperatureLogger app version 1.2 onwards.
Posted: Sun Aug 27, 2017 6:29 pm
by TheHogNL
Could you check the code for the saveLat saveLon? I think it is not saving the lat/lon into the .txt. file when only clicking the map. It looks like it only saves when entering it manually.
I noticed this because I was stuyding how you did the save to the txt file for my own app
regards, Igor
Posted: Sun Aug 27, 2017 8:46 pm
by Toonz
TheHogNL wrote:Hi,
Thanks, good catch !!
Functions to save the new coordinates were not even called when clicking on the map.
Already patched now, plus some cosmetic changes on that screen (labels did not fitting correctly).
Will show up in the ToonStore in the near future.....
Posted: Mon Aug 28, 2017 2:01 pm
by aritmeester
Hi Toonz,
Thanks for all your efforts in building this much better Buienradar app. I really like the app.
I have one cosmetic changerequest. Toon is displaying the room temperature without the Celsius sign. The outside temperature on the Buienradar tile is displaying the Celcius sign. Is it possible to remove the Celcius sign?
I think Celcius is the common unit for the service area of Toon.nl
Thanks!
Posted: Mon Aug 28, 2017 5:02 pm
by Toonz
aritmeester wrote:Hi Toonz,
Thanks!
Hi aritmeester,
welcome on this forum. Just checking: what firmware version are you using on Toon?
On my Toon the room temperature is shown with the celcius sign (firmware 4.4.21 but I believe that was the case also on 3.7.9).
Look here for a recent screenshot:
domoticaforum.eu/viewtopic.php?f=87& ... =90#p83077
Posted: Mon Aug 28, 2017 5:16 pm
by aritmeester
Thanks! I am also running on latest (4.4.21) toon firmware version.
The screenshot you are referring to is exactly showing what I want to be optimized.
The Toon values are shown without the C (28,5º and 18,0º). The buienradar temperature is being shown with the C (22,8ºC)
My request is to remove the C from the Buienradar temperature to make the way temperature values are being displayed more consistent.
Posted: Mon Aug 28, 2017 7:19 pm
by Toonz
Got it, I never noticed
