Page 14 of 15
Re: Toon app: DomoticzBoard
PostPosted: Mon Jul 27, 2020 8:14 am
by Joskep
Toonz wrote:On the tile you can have two switches. The images on the tile act as an on/off switch (no need to go to the detail screen to operate the switches).
You can select which switch to show on the tile by simply clicking on the switch name in the screen.
That will be the new left switch on the tile. The old left switch is moved to the right.
And..
Didn't succeed with this; can't change the swicthes, if i click 1 time it turns the switch ON/OFF, but can't change it to another switch.
Could you explain it one more time, sorry.
PostPosted: Mon Jul 27, 2020 8:35 am
by Toonz
And..
On the main screen (not on the tile) click on the name of the switch (that will make the switch show on the tile)
PostPosted: Mon Jul 27, 2020 8:39 am
by Joskep
Thanks! Worked!
Didnt expect it was an option because you don't see anything is you press it, but it works now!
Thanks (again)
PostPosted: Mon Jul 27, 2020 11:16 am
by Toonz
I probably better change it into a button, at least it is clear then that you can push it ;-)
PostPosted: Tue Aug 18, 2020 7:44 pm
by PeJeWe
how can i show a tempsensor ore multiple from domoticz in a tile on my Toon 1?
is this also possible in dim mode
PostPosted: Tue Aug 18, 2020 10:41 pm
by Toonz
PeJeWe wrote:how can i show a tempsensor ore multiple from domoticz in a tile on my Toon 1?
Current app is only supporting domoticz switches..... Either extend this app to show sensor data as well or write a new specific Toon app for your own purpose (probably the easiest way)
PostPosted: Wed Aug 19, 2020 9:59 pm
by Ossegek
Is it possible to bring the floorplans to domoticzboard?
PostPosted: Wed Aug 19, 2020 10:54 pm
by Toonz
Ossegek wrote:Is it possible to bring the floorplans to domoticzboard?
as far as I can see it is not part of the domoticz API which is used by the Toon app.
The app does supports groups/scenes however, which seems a bit similar.
I am not a heavy user of Domoticz, just have it installed on a raspberry for testing with two lightbulbs.
PostPosted: Thu Aug 20, 2020 5:45 am
by Ossegek
Yes. I can test that for you. Later when i am home
PostPosted: Mon Aug 31, 2020 6:43 pm
by Xavier
Does any one of you use Users in Domoticz?
I have created a user in Domoticz.
I have entered the credentials in the DomoticzBoard app (username and password) but I still see all switches instead of the switches I have connected/added to this specific user.
Seems like username and password in the DomoticzBoard app don't work.
PostPosted: Fri Sep 04, 2020 6:53 pm
by Hypermobile
After no changes on my side.
The buttong won't show up anymore.
- Lan+Internet are working.
Also an minor issue,
Trying to fix it;
i filled in the UserName & Password. no luck
but removing the User+Pass is impossible, after saving, it's there again.
PostPosted: Fri Sep 04, 2020 7:51 pm
by PeJeWe
Xavier wrote:Hi all,
when you put the IP of the toon in domoticz in the field "lokale netwerken" in settings/Instellingen, then you dont have to use users/passwords.
or you can add a IP range example: 192.168.1.*
the star stands for 1 up to 254 range
PostPosted: Fri Sep 04, 2020 9:36 pm
by Hypermobile
Due to that bug, you cannot remove the user + pass....after saving, everything is back to the old Pass/User.
i have 192.168.0.12 as a IP and Port 8084 (Domoticz on a Synoly Nas).
it worked for a Year straight....now it doesn't work ..anymoren on Toon
PostPosted: Sat Sep 05, 2020 2:44 pm
by Hypermobile
i gave my modem a Reset, now it's fixed... :D
PostPosted: Mon Sep 28, 2020 8:04 am
by Xavier
correct IP-adresses already added to local networks (for years) but without any result.....
This has nothing to do with reset of modem or what so ever.
What do you mean with the bug?
