Toon app: ToonStore
Re: Toon app: ToonStore
Postby SDeath » Fri Feb 22, 2019 9:48 pm
I can't update any of the apps using the Toonstore?
I also can't uninstall the apps using the Toonstore?
It just returns to the home screen after pressing "Toon Bijwerken" and does nothing.
Manually removing the app, reboot GUI and try to install via the Toonstore also doesn't work?
I tried rebooting, but somehow it doesn't want to (un)install anything anymore using the Toonstore.
What can I do to fix this?
Toon1 running firmware 5.2.11 (rooted)
SDeath
Postby Toonz » Fri Feb 22, 2019 10:01 pm
most likely you need to fix the hcb_web settings in /qmf/etc/qmf_release.xml.
Especially the tags defaultEntry and enforceWhitelist>.
   <hcb_web>
      <defaultEntry>/qmf/www/</defaultEntry>
      <enforceWhitelist>0</enforceWhitelist>
      <whitelist>
         <item>hdrv_zwave</item>
         <item>happ_zware</item>
         <item>rsrc</item>
      </whitelist>
   </hcb_web>
Postby SDeath » Fri Feb 22, 2019 10:08 pm
You mean the extra spaces in front of those lines?
SDeath
Postby SDeath » Fri Feb 22, 2019 10:18 pm
Changed it to exactly what you had and did a full reboot still doesn't update the apps.
SDeath
Postby Toonz » Fri Feb 22, 2019 10:30 pm
Ok, second usual suspect : /etc/hosts
Can you check whether that looks normal (no double entries)
Postby SDeath » Fri Feb 22, 2019 10:36 pm
it is empty
SDeath
Postby SDeath » Fri Feb 22, 2019 10:45 pm
So that was the problem, I put the content from /etc/hosts.toonstore_backup into the /etc/hosts file and I could update the apps.
Thanks for pointing me in the right direction, but how could this happen?
SDeath
Postby MP51 » Sat Feb 23, 2019 8:41 pm
Running firmware version 4.13.6
After i update toonstore from 2.0.2 to 2.1.2 i have the following issue,
When i try to update app's i get the message firmware update available and the message and download icon are shown
But the app that i select in the toonstore isn't updating.
What could be the reason ?
MP51
Postby MP51 » Mon Feb 25, 2019 1:15 pm
issue solved by updating toon to version 5.0.4 :D
MP51
Postby WickedMaster » Mon Feb 25, 2019 11:18 pm
opkg install http://files.domoticaforum.eu/uploads/T ... r0_qb2.ipk
Downloading http://files.domoticaforum.eu/uploads/T ... r0_qb2.ipk.
Installing toonstore (2.1.2-r0) to root...
Executing pre-install script for toonstore-2.1.2
Hmmm ... no project file found. Shouldn't happen.
Known error?
Edit: Fixed it by creating qmf_release.xml manually. I think I somehow deleted it accidentally.
WickedMaster
Postby Toonz » Tue Feb 26, 2019 12:05 am
As we stated in the install script :this should never happen.... :). Glad you fixed it. Would like to hear from others if they experience the same
Postby TerrorSource » Tue Feb 26, 2019 9:33 am
Known error?
On what firmware did you receive this error?
I had the same error on a 5.0.4 (officially updated to 5.0.4) Toon, which was never rooted before.
TerrorSource
Postby WickedMaster » Tue Feb 26, 2019 9:58 am
This was also on a 5.0.4, updated manually. But this one was rooted already.
WickedMaster
Postby richardklasens » Thu Feb 28, 2019 9:53 pm
MP51 wrote:Running firmware version 4.13.6
Had almost the same, my /etc/hosts file had 2 lines with 127.0.0.1 , one for local and one for feed.hae.int
richardklasens
Postby richardklasens » Thu Feb 28, 2019 10:07 pm
and also no luck... My toonstore won't install or remove apps.
SW 2.12
Firmware 5.04
I've checked hosts and the lines in qml_release. nothing strange... i guess.
Help :)
richardklasens
PreviousNext
Return to Toon Apps
