Toonz wrote:can you post here the last block of /mnt/data/update/_opkg.???-uni-9.9.99.script.sh.log?
Hi Toonz,
Just when I was about to post the log I noticed that it was now missing another tsc-certificates dependencies.
After installing the latest version (1.1.0) instead of just 1.0.1 the issue has been solved and everything works fine!
Perhaps it's possible to install these automatically when installing the toonstore?
EDIT: Buienradar seems to have installed just fine. Just tried to install remaining apps that I wish to use but no luck.
Also the log file hasn't been adjusted/updated since the installation of buienradar so there isn't any information to gather from there.
EDIT2: the log file seems to be the only file in the update folder. There used to be more files including the script.
Somehow these were removed after the buienradar installation.
Thanks for your response!
>> Package cache: /mnt/data/update
>> opkg --cache /mnt/data/update install --download-only buienradar
Downloading
http://files.domoticaforum.eu/uploads/T ... r0_qb2.ipk.
>> opkg --cache /mnt/data/update install --download-only tsc-certificates
Package tsc-certificates (1.1.0-r0) installed in root is up to date.
>> downloaded:
124.0K total
>> dropboxMessage buienradar-8.4.1BRBRBekijk de berichten voor deze software voor informatie over eventuele configuratie.
>> no packages to be removed
>> 2019-03-08 20:42:24 +0100 (pid 4905), status = prepared
>> 2019-03-08 20:42:26 +0100 (pid 5064), status = execute
>> 2019-03-08 20:42:26 +0100 (pid 5064), status = executing
>> opkg --cache /mnt/data/update install tsc-certificates
>> opkg --cache /mnt/data/update install buienradar
Installing buienradar (8.4.1-r0) to root...
Copying /mnt/data/update/buienradar_8.4.1-r0_qb2.ipk.
Running preinstall for buienradar-8.4.1
New installation of buienradar, nothing to be done ...
Executing post-install script for buienradar-8.4.1 ...
Writing app version number to /HCBv2/qml/apps/buienradar-8.4.1/version.txt ...
Adding buienradar to Globals.qml
sed: /HCBv2/qml/qb/base/Globals.qml: No such file or directory
Creating symbolic link /HCBv2/qml/apps/buienradar to /HCBv2/qml/apps/buienradar-8.4.1
Firmware version 5 or greater detected, changing app for firmware compatibility...
Posting message ...
Configuring buienradar.
>> deleting /tmp/dependencies_to_install.txt
>> deleting /tmp/packages_to_install.txt
>> reinstating cache handling (default 0)
>> deleting /tmp/install_status
>> deleting all in /mnt/data/update
>> (this may give some errors, no problem here ...)
>> 2019-03-08 20:42:33 +0100 (pid 5064), status = executed
>> Restarting qt-gui and hcb_config ...
