Toon app: ToonStore
Re: Toon app: ToonStore
Postby wirdo02 » Sun Mar 10, 2019 12:39 am
Toonz wrote:empty hosts files on Toon are not good :-).
Mine looks like this (the localhost.localdomain line must be present as well for ToonStore (and other functionality I guess) to work properly)
# <persistent /etc/hosts content can be added to /etc/hosts.template file>
127.0.0.1      localhost.localdomain      localhost      eneco-001-xxxxxx
127.0.0.1      feed.hae.int      feed
That was indeed the case. Nu clue how come this was empty.
Thanks!
wirdo02
Postby aabre » Sun Mar 10, 2019 9:39 am
Thanks!
Ik think the problem with empty files are the write buffer, the best thing to do after editing files is to use the command 'sync' before removing the power from the Toon.
aabre
Postby TheHogNL » Sun Mar 10, 2019 10:29 am
True. Even better just hit 'reboot' and don't power cycle.
Postby Fietspomp » Mon Mar 11, 2019 11:54 am
Hey guys, my ToonStore is also acting up (5.0.4 firmware).
Impossible to update apps, when I click "Bijwerken" I get a banner that a Toon update is available and that's it...
Tried to install the libssl, got this error:
Installing libssl (0.9.8m-r14.1) to root...
Collected errors:
* opkg_install_pkg: Package libssl md5sum mismatch. Either the opkg or the package index are corrupt. Try 'opkg update'.
* opkg_install_cmd: Cannot install package libssl.
Is it safe to do opkg update?
Fietspomp
Postby TerrorSource » Mon Mar 11, 2019 11:56 am
Fietspomp wrote:Hey guys, my ToonStore is also acting up (5.0.4 firmware).
Collected errors:
Normally you shouldn't be doing an "opkg update". Can harm more then it fixes.
Did you do a "opkg install libsslurlofthisforum" ?
TerrorSource
Postby Fietspomp » Mon Mar 11, 2019 12:05 pm
Yes I tried directly with the url, also tried by copying and installing. same error.
Also tried the update script with the -f flag again, to see if this fixes anything.
Also rebooted to see if it helps. Nothing.
Here's my log (_opkg.qb2-uni-9.9.99.script.sh.log):
>> 2019-03-11 10:29:19 +0100 (pid 24171), status = preparing
>> Firmware version: 4.22.7, build 1273, rev 0.
>> System load     : 17.03
>> Free RAM        : 89244K
>> Flushing file system buffers and cache ...
>> Free RAM now    : 90476K
>> Hotfix for writing System Time to RTC
Hardware Clock before: Mon Mar 11 09:29:23 2019  0.000000 seconds
Hardware Clock after : Mon Mar 11 09:29:25 2019  0.000000 seconds
>> Installing toonstore-2.1.2
>> Extracting packages from the following repo('s):
src/gz tsc1 http://files.domoticaforum.eu/uploads/Toon/apps/toonstore-2.1.2
>> configured opkg feeds:
>> opkg update
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/toonstore-2.1.2/Packages.gz.
Inflating http://files.domoticaforum.eu/uploads/Toon/apps/toonstore-2.1.2/Packages.gz.
Updated list of available packages in /var/lib/opkg/tsc1.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/toonstore-2.1.2/Packages.sig.
Signature check passed.
>> Package cache: /mnt/data/update
>> opkg --cache /mnt/data/update install --download-only toonstore
Multiple packages (toonstore and toonstore) providing same name marked HOLD or PREFER. Using latest.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/toonstore-2.1.2/toonstore_2.1.2-r0_qb2.ipk.
cat: can't open '/tmp/dependencies_to_install.txt': No such file or directory
>> downloaded:
44.0K   total
>> dropboxMessage toonstore-2.1.2BRBRBekijk de berichten voor deze software voor informatie over eventuele configuratie.
>> Removing wastecollection-4.19
>> opkg remove wastecollection
Running postrm on /HCBv2/qml/qb/base/Globals.qml
Removing stale link /HCBv2/qml/apps/wastecollection
Removing wastecollection from Globals.qml
sed: /HCBv2/qml/qb/base/Globals.qml: No such file or directory
Removing wastecollection from customapps
Removing files
Removing package wastecollection from root...
>> dropboxMessage wastecollection-4.19BRBR
>> 2019-03-11 10:29:44 +0100 (pid 24171), status = prepared
Anybody got an idea?
Also tried re-installing the firmware using the root script, no progress, still the same.
Tried removing and re-installing the ToonStore, also did not help.
EDIT: Some steps further, found libssl mentioned in /var/lib/opkg/oe-2.6.36-base-r17-splash2 with MD5. Removed that snippet and was able to install the one from the forum.
Still ToonStore isn't installing/updating apps though.
Fietspomp
Postby Ron_nl » Tue Mar 26, 2019 2:30 pm
Hello Guys and girls,
I am a newbie and having a few issues with my rooted Toon.
First of all I am absolutely not a whizkid (past the kid stage a long time ago.. ;) ) the knowledge I have is by doing lots of reading,
been reading here for months now.
And finally got myself a 2nd Toon which I wanted to root, but stumbled upon 2 problems (so far lol);
1. Toonstore icon is not showing up after installing toonstore 2.1.2
2. Still getting the "geen verbinding met service center" message
What do I have;
Toon 1 software 5.0.4
Rooting using the automated rooting script and a raspberry pi went flawless.
Am able to login using Putty SSH
Tried to install the Toonstore using "opkg install http://files.domoticaforum.eu/uploads/T ... r0_qb2.ipk"
Output:
Downloading http://files.domoticaforum.eu/uploads/T ... 2.1.2/toon store_2.1.2-r0_qb2.ipk.
Installing toonstore (2.1.2-r0) to root...
Executing pre-install script for toonstore-2.1.2
New installation of toonstore.
Backing up public keyring ...
Backing up /etc/hosts ...
Editing /etc/hosts to enable toonstore ...
hcb_config process ID now: 2671
Restarting hcb_config ...
Waiting for 3 seconds ...
hcb_config process ID now: 5120
Creating backup for /qmf/etc/qmf_release.xml ...
Patching /qmf/etc/qmf_release.xml for 403-forbidden error ...
Restarting http server ...
Cleaning garbage....
rm: can't remove '/HCBv2/qml/apps/toonstore/*.qmlc': No such file or directory
rm: can't remove '/HCBv2/qml/apps/toonstore/*.jsc': No such file or directory
rm: can't remove '/HCBv2/qml/apps/toonstore/*.txt': No such file or directory
ToonStore pre-install script completed ...
Configuring toonstore.
Executing post-install script for toonstore-2.1.2 ...
Writing app version number to /HCBv2/qml/apps/toonstore-2.1.2/version.txt ...
Adding toonstore key to opkg keyring ...
OK
This is a Toon QB2, checking to Globals.qml
No settings to be restored
Creating symbolic link /HCBv2/qml/apps/toonstore to /HCBv2/qml/apps/toonstore-2.1.2
Firmware version 5 or greater detected, changing app for firmware compatibility...
Posting message ...
eneco-001-067938:~#
Rebooted, but there is nothing showing up. In fact it looks like a unrooted Toon.
When I use an FTP program I can see the maps /qmf/qml/apps//toonstore and toonstore-2.1.2
Tried to uninstall, reboot, checked edit "/var/lib/opkg/status" file and check if ToonStore + ToonStore apps exists in that file, if so, remove the lines from that app.
No status file there.
Re-Installed the Toonstore, still nothing.
Do get the "email" message that the Toonstore is installed.
I used the forum search option for finding out a solution to a similar problem but could not find anything.
Can you help me?
Thanks in advance.
Ron.
Ron_nl
Postby ovdleun » Wed Mar 27, 2019 7:24 pm
Hi Ron,
What do I have;
I have (had) the exact same issue. Rooted yesterday, edited the config config_happ_scsync.xml to 're-enable' my Toon (this caused all tiles and history to be available again).
Installed Toon store by downloading toonstore_2.1.2-r0_qb2.ipk to my Toon and installed it with: # opkg install toonstore_2.1.2-r0_qb2.ipk
No errors (except with removing garbage) during install. For output see Ron's message.
No Toonstore tile to be found. Rebooted Toon, still no tile.
Regarding issue 2 of Ron, I guess you have the same issue as me that there are no QML files to be found right?
Therefore I posted this reply: viewtopic.php?f=96&t=11449&p=90353&e=90353
@marcelr was so kind to reply almost instantly, just saw it and tried it before finishing this post. I followed this advices and also ran their (TheHogNL & TerrorSource & yjb) update-rooted.sh ... who guessed ... seems they have some additional magic on their hands!
Downloaded update-rooted.sh from https://github.com/IgorYbema/update-rooted and ran it with:
# sh update-rooted.sh -f
After the script finish I rebooted Toon by running "# reboot", after that all was as expected:
- SC message gone
- ToonStore was installed and available
- Afvalkalender installed succesfully
So I guess I'll have a look into the script to see what I missed. But made a donation to them, as I appreciate this kind of effort. And many thanks to for his quick response and solution.
Hope it helps you too.
Onno.
ovdleun
Postby TheHogNL » Wed Mar 27, 2019 7:53 pm
@Onno, thanks for the donation.
The reason is because of this https://www.domoticaforum.eu/viewtopic.php?f=96&t=12071
Since 4.16.8 everything on the GUI side is loaded using resource files and we now publish modified resource files which load the custom apps for you.
The update script with option -f download the resource file for you (and does a few other changes to your toon used by most people)
Postby Ron_nl » Wed Mar 27, 2019 10:43 pm
FIXED!! :D
Thanks Onno for the answer, the sh update-rooted.sh did the trick.
Just finished the install, and it looks like everything is working fine now.
Also a big thank you to all the developers doing a amazing job for the Toon!
Gonna play now with my new toy.. :mrgreen:
Ron.
Ron_nl
Postby Daniel » Fri Apr 05, 2019 2:40 pm
I also installed toonstore but, no shopping basket on top of the screen.
Running on firmware 5... is the update script the trick for me to?
Daniel
Postby TerrorSource » Fri Apr 05, 2019 5:22 pm
Daniel wrote:I also installed toonstore but, no shopping basket on top of the screen.
Press "Menu" button on the top left corner, open "ToonStore" and edit the settings to show on taskbar.
TerrorSource
Postby Daniel » Fri Apr 05, 2019 5:46 pm
There is no toonstore in the menu.
Daniel
Postby TheHogNL » Fri Apr 05, 2019 6:00 pm
Run "update-rooted.sh -f" to set all files correctly for rooted toons, to allow custom apps to run.
Postby Daniel » Fri Apr 05, 2019 7:31 pm
TheHogNL wrote:Run "update-rooted.sh -f" to set all files correctly for rooted toons, to allow custom apps to run.
Thanks! That was the trick , toonstore is working on this toon.
I also have another toon with firmware 4.9.23 and toonstore but when I push toonstore bijwerken nothing happened.
I try the update-rooted.sh -f script but that didn’t work.
Daniel
PreviousNext
Return to Toon Apps
