Page 3 of 22
Re: Toon app: ToonStore
Posted: Fri Sep 08, 2017 4:42 pm
by Marijn
Thanks I look into date before the next firmware update. [emoji6]
Posted: Fri Sep 08, 2017 4:59 pm
by TerrorSource
Marijn wrote:Thanks I look into date before the next firmware update. [emoji6]
Its only the iptables part. dropbear is still installed but it can't be reached because the port is not open.
Best is to re-do the first part of the rooting process.
Posted: Fri Sep 08, 2017 11:10 pm
by phoenixb
Small question / request. Is it possible to temporarily recover the file inside the toon to made an connection with the SC?
I have removed the app but it looks that it not recover that part.
Posted: Sat Sep 09, 2017 10:17 am
by Toonz
phoenixb wrote:Small question / request. Is it possible to temporarily recover the file inside the toon to made an connection with the SC?
First of all , did you do a full reboot (not a qui-restart), because that will activate the VPN again to the SC?
If that doesn't help check the following:
check the file /etc/inittab, remove the '#' if it is there to start the vpn
#ovpn
respawn:/usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0 >/dev/null 2>&1
Secondly, the host file needs a correct entry for the SC url:
file /etc/hosts, check for the line with feed.hae.int .
If the IP address is 127.0.0.1 then replace the hosts file with the file hosts.toonstore_backup.
Hope this helps.
Posted: Sat Sep 09, 2017 3:45 pm
by TheHogNL
Toonz wrote:Secondly, the host file needs a correct entry for the SC url:
Actually, the feed.hae.int entry in /etc/hosts will be automatically set correctly when the vpn is working. (I think hcb_netcon does this).
There are a lot of possible entries of the feed.hae.int IP-address and it depends on what VPN connection from the Eneco server you are connected to (first IP address of the subnet)
So no need to 'repair' the /etc/hosts file from the hosts.toonstore_backup.
I guess that he only needs to wait a day or more. Automatic software update isn't checked all the time. I have seen a entry in a log file once that it was checking somewhere in the morning.
Posted: Sat Sep 09, 2017 4:35 pm
by phoenixb
I have restore the points as given.
But I was hoping that the new update was receiving with an restart, bult I think I must wait for an longer time.
@TheHogNL have you find something like an manual update or is this an server based process from Eneco?
Posted: Sat Sep 09, 2017 5:03 pm
by TheHogNL
phoenixb wrote:I have restore the points as given.
The updates can be pushed by Eneco. That is often the case with the most recent version (like 4.7 now). The older versions should be ready for your Toon to get automatically if I understand correctly but don't know how often the 'Toon checks if there is an update.
Manually updating will probably not work as the update requires a shell file to be excecuted which is part of the update. Don't know how to get that shell file manually.
Posted: Sat Sep 09, 2017 9:16 pm
by hanplo
I have rooted my Toon. Is it normal the Toon shut down every day and restart again? It happens one or twice a day.
Posted: Sun Sep 10, 2017 8:35 am
by Toonz
hanplo wrote:I have rooted my Toon. Is it normal the Toon shut down every day and restart again? It happens one or twice a day.
Toon restarts itself if it runs out of system resources. Maybe you have to many apps installed? Try removing /disabling ones you don't really need
Posted: Mon Sep 18, 2017 7:08 pm
by michel30
In the Toonstore I see that buienradar 8.0.10 but it says installed version 8.0.9
- 2017-09-18_19.jpg (15.62 KiB) Viewed 11065 times
Posted: Tue Sep 19, 2017 8:02 am
by Toonz
michel30 wrote:Hello,
I guess you are running firmware version 3.x.
In the ToonStore repository we enabled buienradar 8.0.9 only for fw version 4 and above.
Version 8.0.10 is compatible again with all firmwares but we forgot to update the firmware requirement again in the repository.
This has been corrected now. Can you refresh the ToonStore and try again?
If it still doesn't work: which firmware version do you have and which version of ToonStore?
A later version of ToonStore will show proper messaging in these cases.
Posted: Tue Sep 19, 2017 6:28 pm
by Toonz
It's a stupid bug in ToonStore, it thinks 8.0.9 is higher than 8.0.10......
Will repackage buienradar as 8.1.0 and fix it in ToonStore in the next release
Kind Regardz,
Posted: Tue Sep 19, 2017 7:22 pm
by michel30
Hello Toonz,
Thanks for your information, that it is a bug in the ToonStore.
My firmware is 4.4.21 if I want to upgrade to the latest firmware than I need to open the Toon again because you will loose the ssh connection.
Michel
Posted: Tue Sep 19, 2017 7:58 pm
by marcelr
You can prevent that by patching base-qb2-ene-<whatever>.ipk prior to installation. This package contains the firewall settings (/etc/default/iptables.conf). Unpack it (with tar -zxvf base-qb2-ene-<whatever>, then unpack data.tar.gz , edit iptables.conf, repack (twice) and run the update.
reboot an log in to your toon normally.
Posted: Tue Sep 19, 2017 10:06 pm
by Toonz
Buienradar 8.1.0 is now on ToonStore (copy of 8.0.10) to work around this ToonStore bug (Thanks MarcelR)
Click the refresh button in the ToonStore to make it visible.
The final fix of the ToonStore will be included in next version of the ToonStore but there is no hurry as no other apps are impacted soon.
