Page 6 of 7
Re: Toon app: Dashticz (for Toon); NEW: OV Info (NL)
Posted: Mon Jan 07, 2019 1:35 pm
by TerrorSource
ArieKanarie wrote:Now that Dashticz is working Toon becomes unresponsive most of the times.
When I get to the dashticz screen it shows most of the times "loading switches"
The maker of Dashticz problably needs to update his app to comply with the latest firmware changes but he hasn't logged on onto this forum in a while.
I've also tried to contact him through different ways but never received a reply from him...
Posted: Tue Jan 08, 2019 10:55 pm
by ArieKanarie
That is too bad.
From what I remember from the domoticz forum it happened before that he had some kind of brake, I guess he has a live besides dashticz :lol:
I will check over there , and otherwise there is nothing left then being patient :)
Posted: Wed Jan 16, 2019 9:47 am
by Xavier
Any News about an update yet?
Dashticz and OV both don't work.
It looks like no data is being fetched.
As Ariekanarie says "loading switches"
Posted: Wed Jan 16, 2019 10:15 am
by Xavier
facing the same issue here,
No data is being loaded.
Posted: Thu Jan 24, 2019 9:05 pm
by atlantica
Hi Domoticz users....
This app should work on 4.22.7 I cant get it working on 5.0.4 for now:
Just edit DomoticzBoardApp.qml
//Server connection settings:
property string username: "" //see https://www.base64encode.net/
property string password: "=" //see https://www.base64encode.net/
property string hostName: "0.0.0.0"
property string portNum: "8080"
//Stop editing here!
//Position 1 settings switch1idx:
property string switch1idx: "88" //put IDX of switch/wall plug here
property string switch1StatusIcon
property string switch1Name
//Position 2 settings switch1idx:
property string switch2idx: "76" //put IDX of switch/wall plug here
property string switch2StatusIcon
property string switch2Name
//Position 3 settings switch1idx:
property string switch3idx: "87" //put IDX of switch/wall plug here
property string switch3StatusIcon
property string switch3Name
//Position 4 settings switch1idx:
property string switch4idx: "91" //put IDX of switch/wall plug here
property string switch4StatusIcon
property string switch4Name
//Position 5 settings switch1idx:
property string switch5idx: "90" //put IDX of switch/wall plug here
property string switch5StatusIcon
property string switch5Name
//Position 6 settings switch1idx:
property string switch6idx: "89" //put IDX of switch/wall plug here
property string switch6StatusIcon
property string switch6Name
//Position 7 settings switch1idx:
property string switch7idx: "62" //put IDX of switch/wall plug here
property string switch7StatusIcon
property string switch7Name
//Position 8 settings switch1idx:
property string switch8idx: "98" //put IDX of switch/wall plug here
property string switch8StatusIcon
property string switch8Name
Posted: Fri Jan 25, 2019 1:30 pm
by Xavier
@David,
don 't know if I understand correctly...
Does the app work on 5.0.4 or not?
Because of the remark "for now"...you say "just edit".
Posted: Fri Jan 25, 2019 4:36 pm
by mAiden
Xavier wrote:@David,
No, its not working yet on 5.0.4
Need some re-coding for that
Posted: Fri Jan 25, 2019 8:15 pm
by atlantica
that is correct! But for now I dont't have the knowledge to correct the script myself...
Posted: Mon Jan 28, 2019 8:41 pm
by atlantica
Hi Domoticz users,
This one is working with 5.0.4 :)
Posted: Wed Feb 06, 2019 3:40 am
by f_hertgers
Thx mate supurb work for this app en all the rest on this forum : ) !
After copy these files to /qmf/qml/apps/DomoticzBoard
Toon a Hard reboot .
There is no pressent of a new app.
The file " DomoticzBoardApp.qml"" is emty ?
What i do wrong ?
Posted: Wed Feb 06, 2019 8:40 pm
by atlantica
which toon version do you use 5.0.4 or 4.22.7?
Posted: Thu Feb 07, 2019 1:02 am
by f_hertgers
My Toon runs on 5.0.4 , updated yesterday with a suppurb sript from a member of this forum
Posted: Thu Feb 07, 2019 3:02 pm
by mAiden
@atlantica
If you agree, I would like to expand Domoticzboard further, as Dashticz is now. Have already changed some icons, so that it looks more beautiful and quieter, I am now working on adding dimmers and text sensors.
When that is finished I will ask Toonz to add Domoticzboard to ToonStore.
As a maker, your name is also underneath :)
Posted: Thu Feb 07, 2019 3:11 pm
by TerrorSource
mAiden wrote:@atlantica
DomoticzBoard is still originally created by me :) So please ask me first before you do anything :o
And there is a seperate topic for all DomoticzBoard related issues/questions. This is the topic for Dashticz and not for DomoticzBoard :)
Posted: Sat Feb 09, 2019 2:53 pm
by atlantica
If i'm right everyone can develop apps for toon?!. And of course learing from other users code is logic to me.... :(
