DennisD
Post by DennisD »
DennisD wrote:Well, I will try to connect my non rooted today and include my meteradapter to it. If that solves the issue I will root it. Is the latest software 4.4 still rootable? Because I know there was a software update on that one but didn't bother with updating. That one is still subscribed with eneco
Updated my rooted one tot 4.4.21 and downgraded the happ_thermostat and everything is working great now (just missing the double e meter function high/low rate).
makkie2002
Post by makkie2002 »
I also upgraded successfully to 4.4.21 ... still root :D
I however have a question on what you guys have as apps in your "menu".
I seem to be missing "rookmelder" and "bedien opties".
I think they were also not available when I was still at 3.x (not sure).
Have a look at my screenshot:
ronalddehaan
Post by ronalddehaan »
Hi Guys,
My name is Ronald and I am new here. I will be trying to root my Toon soon so it seemed like a good idea to register an account here in case I have questions.
Turns out; i already have a question.
I've purchased the USB 2.0 To TTL 6PIN Module from hobbyelectronica.nl/product/ch340g-seri ... converter/ as suggested somewhere in the beginning of this topic.
When plugged in it's recognised by Windows just fine. Problem is; how do I attach the wires to it :D Seems basic, I know :lol:
Hope you guys can point me in the right direction :D
All described at the rooting manual in the Manuals/Tutorials topic :domoticaforum.eu/viewtopic.php?f=87& ... mp;t=11235
TerrorSource
Post by TerrorSource »
makkie2002 wrote:I also upgraded successfully to 4.4.21 ... still root :D
Thats because you didn't activate your Toon.
There's a small how-to somewhere on the forum :)
phoenixb
Post by phoenixb »
Small question, i have install the VNC package only on reboot i have the next overview:
eneco-001-015883:~#
The SSL VNC desktop is:  eneco-001-015883:9
PORT=5909
SSLPORT=5909
The SSL VNC desktop is:  eneco-001-015883:10
PORT=5910
SSLPORT=5910
The SSL VNC desktop is:  eneco-001-015883:11
PORT=5911
SSLPORT=5911
The SSL VNC desktop is:  eneco-001-015883:12
PORT=5912
SSLPORT=5912
The SSL VNC desktop is:  eneco-001-015883:13
PORT=5913
SSLPORT=5913
The SSL VNC desktop is:  eneco-001-015883:14
PORT=5914
SSLPORT=5914
The SSL VNC desktop is:  eneco-001-015883:15
PORT=5915
SSLPORT=5915
The SSL VNC desktop is:  eneco-001-015883:16
PORT=5916
SSLPORT=5916
The SSL VNC desktop is:  eneco-001-015883:17
PORT=5917
SSLPORT=5917
The SSL VNC desktop is:  eneco-001-015883:18
PORT=5918
SSLPORT=5918
could not fork
fork: Cannot allocate memory
And after the last one it's freeze, have I done something wrong?
__________________
Hmmm ... race condition in inittab, please remove x11vnc from inittab and start it manually. You are not the only one, apparently. Need to look into that.
phoenixb
Post by phoenixb »
Is it possible because i have at this moment an low SW version? (2.xx)
__________________
Could be. I don't really know what's causing this (yet).
phoenixb
Post by phoenixb »
Small update : firmware update with the original fw. And looks now that vnc is working.
__________________
ronalddehaan
Toonz wrote:All described at the rooting manual in the Manuals/Tutorials topic :domoticaforum.eu/viewtopic.php?f=87& ... mp;t=11235
Besides that i am more of a "view picture" kinda guy I have to connect the headers to both ends, to the USB stick and to the board.
The board part is described so i should be able to figure it out but that still leaves me with the usb stick header.
I'll try to upload a picture to make the thing clear :)
No doubt there will be markings GND, TxD, RxD, Vcc, 5V and 3.3V on the other (in this picture invisible) side of the PCB.
makkie2002
Can someone point me to a (free) VNC viewer for iOS that works with the VNC server of Toon.
The ones I tried do not work, probably due to the special SSL encoding scheme in the VNC server of Toon.
Maybe it is possible to start the x11vnc with options to use other type of encryption that the "normal" VNC viewers understand?
For me encryption is not required because I always connect to my home network via VPN.
TerrorSource
makkie2002 wrote:Hi,
im using ssvnc, a custom vnc application.
http://www.karlrunge.com/x11vnc/ssvnc.html
makkie2002
Thanks, but I am specifically looking for a VNC viewer for apple ipad/iphone (iOS).
Best would be to have the option to turn off the encryption in the x11vnc server of Toon.
Return to “Toon Rooting”
