For your information: the documentation of the new
Xanura IMX10 module (
http://www.waakzaamwonen.nl/catalog/pdf/imx10.pdf) contains the following text "Please note: Depending on the make/type of mechanical ventilation unit used, additional relays (Eaton no.: 1810 103) may be needed to use these mechanical ventilation circuits in combination with XanuraHome. Before using this circuit, make sure that the mechanical ventilation unit used can be controlled with XanuraHome. Check with the XanuraHome Step by Step Plan for more information. This can be downloaded from
http://www.xanurahome.nl .". The step by step plan (
http://www.xanurahome.nl/Portals/0/pdf/ ... enplan.pdf , dutch) mentions a couple of AC ventilation units (Stork-Air CML, Itho CVE166, CVE266) that work without additional relay, but a DC unit (Itho CVE ECO-fan2) that requires the relay. Mine (a Stork CMFe) is also DC, so this may very well be the problem. I asked
Xanura and they said they don't know because they can't test every type and I just have to try and see if it works. Not very helpful, but I will do so as soon as I find an appropriate relay (and some more time).
