TheHogNL wrote:
And did you configure the imp/kwh on the Toon correctly?
I think so where can I change this on the
toon ? .. fyi the 2000 impulse thing .. is the same as posts in this thread .. so I think it should be not to far off .. hard to compare A to B currently .. (
toon vs direct data from inverter) ..
I don';t think i need to change a lot .
Default settings is 10000 imp/kwh. You can configure this in the meteradapter setting under solar.
In you overview I'm missing some P1 data, like elec_delivered_lt
Please show the whole json output. and not your translated to nodered.
Show, elec_delivered_lt and elec_received_lt show the data from P1 (and lt is low tariff, nt is normal tariff). Then there is the solar data in the same json output.
When you are producing enough energy (solar is high number) then elec_received should be 0 (you are not importing) and elec_delivered should be higher than 0 (and actually would be solar minus "house usage"). This house usage is what
toon is showing in the tile.
if Default settings is 10000 imp/kwh. You can configure this in the meteradapter setting under solar. (0.1 imp/wh)
never mind found the setting
the json as requested.
{"dev_settings_device":{"uuid":"46c2bbf9-b6f7-4c4f-8abd-9893c5f1f116","name":"settings_device","internalAddress":"settings_device","type":"settings_device"},"dev_3":{"uuid":"e42ff449-99c8-445d-858c-af2e0644ebb4","name":"HAE_METER_v3","internalAddress":"3","type":"HAE_METER_v3","supportsCrc":"1","ccList":"5e 86 72 32 56 5a 59 85 73 7a 60 8e 22 70 8b 3c 3d 3e","supportedCC":"5e 86 72 32 56 5a 59 85 73 7a 60 8e 22 70 8b 3c 3d 3e","nodeFlags":[],"IsConnected":"1","DeviceName":"HAE_METER_v3","HealthValue":"10","CurrentSensorStatus":"UNKNOWN"},
"dev_3.1":{"uuid":"17f68ff1-682a-4b76-8e4e- b24c8044b841","name":"HAE_METER_v3_1","internalAddress":"3.1","type":"gas","supportsCrc":"0","nodeFlags":[],"CurrentGasFlow":"7.00","CurrentGasQuantity":"5215004.00","DeviceName":"HAE_METER_v3_1"}
,"dev_3.2":{"uuid":"65b7d0c9-be88-493b-92f0-399a1cada283","name":"HAE_METER_v3_2","internalAddress":"3.2","type":"elec","supportsCrc":"0","nodeFlags":[],"CurrentElectricityFlow":"NaN","CurrentElectricityQuantity":"NaN","DeviceName":"HAE_METER_v3_2"},
"dev_3.3":{"uuid":"0f369c1c-bd83-43d8-bc44-20460ee62dd4","name":"HAE_METER_v3_3","internalAddress":"3.3","type":"elec_solar","supportsCrc":"0","nodeFlags":[],"CurrentElectricityFlow":"NaN","CurrentElectricityQuantity":"NaN","DeviceName":"HAE_METER_v3_3"},
"dev_3.4":{"uuid":"e0b1c66b-7914-41f8-a61e-a59249508b44","name":"HAE_METER_v3_4","internalAddress":"3.4","type":"elec_delivered_nt","supportsCrc":"0","nodeFlags":[],"CurrentElectricityFlow":"0.00","CurrentElectricityQuantity":"9060929.00","DeviceName":"HAE_METER_v3_4"},
"dev_3.5":{"uuid":"543f8db1-616d-41dd-be14-bbdd8fb2d609","name":"HAE_METER_v3_5",
"internalAddress":"3.5","type":"elec_received_nt","supportsCrc":"0","nodeFlags":[],"CurrentElectricityFlow":"1049.00","CurrentElectricityQuantity":"417753.00","DeviceName":"HAE_METER_v3_5"},
"dev_3.6":{"uuid":"43774ffe-9ff7-4bc6-8191-8d6a9c0df838","name":"HAE_METER_v3_6","internalAddress":"3.6","type":"elec_delivered_lt","supportsCrc":"0","nodeFlags":[],"CurrentElectricityFlow":"0.00","CurrentElectricityQuantity":"12459168.00","DeviceName":"HAE_METER_v3_6"},
"dev_3.7":{"uuid":"688288c4-0552-4bb3-815c-733d6d4ee611","name":"HAE_METER_v3_7","internalAddress":"3.7","type":"elec_received_lt","supportsCrc":"0","nodeFlags":[],"CurrentElectricityFlow":"0.00","CurrentElectricityQuantity":"169615.00","DeviceName":"HAE_METER_v3_7"}
<removed 3.8>
