Toon App: solarPanel ---> solar data without hardware
oepi-loepi
Re: Toon App: solarPanel ---> solar data without hardware
Post by oepi-loepi »
Super, ik zal de plugin aanpassen. Bedankt.
Henri
Post by Henri »
Does anybody know if it is possible to connect my SMA tripower 5.0 to this app? The SMA sunny boy options did not work...
Thanks in advance!
Xavier
Post by Xavier »
Just to update you all about this issue with Enphase...
Oepie-Loepi and I are still checking what has to be done to get this to work.
2 ways of doing this:
1. Using the data directly from the Envoy-S metered [url]http://IP_ADDRESS_of_Envoy-S/production.json[/url]
Since the software version on the Envoy-S (D7) a token is needed.
The Enphase Envoy-S can directly be accessed by the using the ip-address, then there is a need of a token to access.
2. Using APIv4 https://developer-v4.enphase.com/
When choosing for the free "developer plan" (named "Watt") https://developer-v4.enphase.com/developer-plans, then you are able to have a max of 1,000 hits per month free of charge.
In consideration I want the Toonv2 to show me the actual solarpower (production) (so I know when I can start large powerconsumption devices like (dish)washer, dreyer, airco, etc) so you need to have the data lets say each minuten, 60(minuts)x24(hours)x31(days) in 1 month = 44.640 hits per month. The APIv4 with developer plan "Watt" is in that case insufficient.
Still investigating and testing.
mvveelen
Post by mvveelen »
I have 2 SMA converters, an SMA Sunny Boy 2.0 and an SMA Sunny Boy 3.6
The SB 2.0 I can read with curl and also works to get data from.
The SB 3.6 doesn't let me use a method to get data from, although I managed to get a reply (like: {"result":{"sid":"ewWXarXBiJMBsqnw"}}) with:
curl -k -H "Content-Type: application/json, Accept-Charset: UTF-8" -X POST -d '{"pass" : "MyPass", "right" : "usr"}' https://192.168.0.xxx/dyn/login.json
Isn't it going to work with this particular SMA SB 3.6 or is there light at the end of the tunnel?
En ja, ik ben wél bereid om toegang te verlenen om iets te testen, ik wil graag beide kunnen uitlezen.... :)
