Plugwise Homeseer Plugin
Yep... That did the trick....
Thanks....
And it looks gooooooooooooooood
Thanks....
OK, I have updated the zip file with a new version of web.config.
Looks good Rene.
Later I have some comments and request.
See below my HStouch image and the new plugin features like the charts.
In HStouch I use the RFXcom virtual usage and I have to find a way to calculate the "overig" usage.
What type of TV do you have in your living room consuming more than 500W?
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by rklootwijk</i>
<br />What type of TV do you have in your living room consuming more than 500W?
It's 46 inch plasma screen and actaully this is also the receiver and setop box etc (let's say Home Entertainment set) and it's a lot, you're right/ I will check if the numbers are correct...
@Rene,
Thanks for the new futures.
Upgrade for me will be a bit difficult because of all the mappings to make toggle in HST possible. Every Plugwise device(30) is mapped to a virtual HS device.
latest this weekend I will do the installation.
This is hopefully the last version that requires you to start all over to implement it. In the next versions I will try to provide an upgrade path without destroying your current configuration.
Hi Rene, THANKS for your great work !
I've installed the new release and I can see all the devices (incl the Special device) in the homepage. Works fine.
I can see the Plugwise Charts page. But there is no chart. Only the text: <b>Total usage</b> and <b>Actual usage</b>. Nothing further.
I am doing research for an hour but I cannot find out what is going wrong. I keep on searching.
Silverlight is running,
WIN XP Prof SP3 and
WIN XP Prof SP3 and
Total usage and Actual usage are links to select the required chart. SO you you have to click on one of them.
<font color="blue"><font size="2"><b>Yes, Yes, Yes !!! Thanks Rene,</b></font id="size2"></font id="blue"> Silly me, did not see they were hyperlink.
<font size="3"><font color="red"><b>Thank Rene, Great job!</b></font id="red"></font id="size3">
Wat betekent de icon met het uitroepteken ???
Het staat bij 2 van mijn devices...
The exclamation mark means the device status is unknown. The plugwise stick is unable to determine the status of the circle.
okay, now it's gone, so I think this was a temporarily situation.
Thanks Rene
Thanks Rene
It most of the time is. This is not something of the plugin but a status that is forwarded by Plugwise.
is it possible to relabel the plugs without really changing the names. i.e. plugwise nows the plug as garden but in the plugin i would like to name it garden (pool side)
