Report Bugs Plugwise Beta Source April 2009
New beta release! V20090507.0
All reported bugs solved.
Where can you find the version of the software you are proesnetly using ?
@Reinder: As in the other beta releases, this beta release still contains a bug on the webserver API. The Appliance.Module.TypeText returns an object instead of a string describing the type of module.
@ jheerink, the version can be found at the right up (next to the button "schedules"), in the blue top/line. It's written in blue numbers. It's hard to see.
@rklootwijk, strange I thought it was solved. I will ask.
Tonight I examined all of my modules in the Source. One of the modules reported a current power usage of 0 while the device, a wireless access point, was turned on. Previously the device reported a continues usage of 7 watt as does my other exact same wireless router. It turned out that since saturday april 4th, no power usage has been reported. Guess what, april 4th was the release of the first beta version of the Source. I deleted the device and created a new device which I could not give the same name because the Source complained that a device with this name already exists. So I used another name and connected the specific circle to this new device. I thought the statistics of the circle would be bound to this new device, but no statistics are available for this device.
Thanks Reiner i found it
(the schoolversion is now V20081110 i applied for a new
beta for this system yesterday.
and an other question
when i push [vernieuwen] on the source the [V] on the stick symbol left bottom starts flashing and there is a time displayed which changes rapidly What does this indicate (I see as example 0:23 then 1:34 2:01 0:34 and changing numbers for a while then it stops.
New beta release! V20090512.0
All reported bugs should be solved.
Finaly appliance.module.typetext returns the correct value;-)
I applied for a beta including my serial. Today after starting up the source, an update was available. It started with a system crash when it tried to backup data, but installation continued. After restart, the schedules of the previous version were changed, some reverted to an earlier scghedule that had been removed some days ago, strange, and some plugs (the stealths i installed the last) were not visible. I started out with changing and adjusting the schedules , which worked ok, and sent them to the plugs. That seemed to work, time will tell if they behave as programmed.
Then i tried to add the missing plugs (4 stealths) In the list with plugs the stealths showed up,automatically, and then i had to add info of them, when i did with the first one,the software informed that the name already existed and the programm hung. I had to do to a restart of the programm (CTRL ALT DEL) and then restart. The first stealth was now visible and i had to do the same to add the other stealths. Program hung several times, and after the 3d restart it missed 13 plugs again, but the info i previously entered (room type etc) was still there so reentry went quick . Finally all plugs and stealth were accounted for (39) and it seems to work ok. version info 20090507.0
So not a very smooth transfer took over an hour to get the system up and running again, hopefully this will not happen too often ,and i hope this version is bugfree, time will tell.
What i also noticed on the previous (non beta) version was that when starting it, sometimes to small popup windows showed up in the color/style the plugwise source software with some numbers in it They disappeared after few seconds and then programm started up normally.
hmmm strange.
My (beta) version is V20090512.0
It looks like you have the wrong version.
I checked for update, there is none. Later this evening we tried to install some new stealths, after pushing the add plugs button, the source started and we added the new plugs on the list, it took a long time (30+ min} and then it found 20 out of 40 plugs, the old version always easily found them all, and we had to put all info of the retrieved plugs in again. Could be because the new software also has a new category in it, that it needs to update it (the type of room info, which is infact only valid for private homes, there are no office catergories in it, so useless for us)Finally we had 20 plugs online including the new ones tomorrow we check if we can get the others back. So far trouble some installation of this beta
Today it finally updated to 20090512, and although it took al long time and several crashes it finally has all the plugs and stealths in and is working now. The version i use at home updated today also to 20090512 but expierenced no problems and had a smooth upgrade
Just found out that there is a new Beta release: beta 20080515
This is the 1st time that the update shows a fix list, so here we go:
Plugwise Source 2, beta 20080515
Changes:
- Updated appliance types and icon list.
Fixes:
- #136 Add module wizard can crash
- #135 New licenses can only be activated manually
- #133 After deleting an appliance, you cannot create a new one with the same name
- #132 Adding new modules can take very long time
Known issues
- While sending switching schedules, all other commands are blocked.
- To send a switching schedule to a Circle+, the Circle+ must be in direct range of the Stick.
- Help button opens a webpage on plugwise.com with apologies for lacking an updated manual.
- Driver for Stick might cause crash on Windows 7 64bit.
Plugwise Source 2, beta 20080512
Changes:
- HTTPS is used for all communication with Plugwise servers.
Fixes:
- #127 Pressing Delete to delete an appliance from a group, results in 2 appliances being removed
- #125 PTE: Module.TypeText returns unusable value
- #124 Room type 'Bedroom' is missing
- #118 Add modules button results in crash
- #104 Crash when editing unassignend appliances
- #100 Context menu's do not show or do not work
- #88 No warning when leaving unsaved switching schedule
- #90 Icon of appliance does not display correct on/off status
- #59 Holes in log data when Source is not running continuously
- #55 Switching schedules result in random switching
Plugwise Source 2, beta 20080424
Changes:
- Language selection dialog in update installer.
- Added Preparation page to Configuration Wizard.
- New switching schedules are filled with 'On' by default.
Fixes since beta 20080415.1
- #82 Update wizard crashes when update has multiple files.
- #76 Peak/Offpeak calculations during weekends
- #68 Last 3 days of 2008 are shown as week 53 instead weak 1 of 2009 (Dutch week numbering)
- #67 Configuration wizard does not use the language as selected during setup.
- #64 Country list in Usage Data and Personal Info forms are empty when Windows phone/modem setting are not set.
- #62 Cannot add new tariffs
- #63 Savings report incorrect when selecting a group or room
- #60 Webserver: Appliance.TypeText and Appliance.Module cause error
Changes:
Fixes:
Known issues
Changes:
Fixes:
Changes:
It,s hard to read the version but it must be 20090518
Since few days I'm also using the beta 20080512.
Controlling via Homeseer is faster then before. Did not notice any problem.
