doorbell and with ds10a possible?
I have an traditional doorbell, and I wamt to keep that, with a button outside, trafo, and a gong. I want to know when the button is pressed, how can I do that, if possible with an ds10a to put the wires that orignall on the screws on the relais, directly on the bell button parallel on the other?
Or are there other options?
regards Richard
regards Richard
Better alternative is the SM10
or simple Kaku doorbell if your have Rfxcom
other options are Visonic products like MCT100..more complex
I've taken a KAKU AMST-606 door sensor apart and modifying it to trigger when my doorbell is rung. It's not 100% reliable yet but once I got it to work I'll put it on the forum. The good thing about the KAKU is that it's cheap (EU 12).
/JW
/JW
I also used the SM10, keeping my existing doorbell, button and trafo. When the doorbell is pressed an X10 signal is send out. Works pretty good.
Warning for sm10!
The spec's are not correct.
under " 9 volt's ac" its not working correct.
Symptoms: after activating sm10 the cm11 is not responding anymore.
gr Ruud
ps Marcel "waakzaam wonen" has made a complain by the manufacturer
gr Ruud
- RDNZL
- Forum Moderator
- Contact:
I use an Xanura SAX35 for this, you can directly connect it to your standard gong/trafo wiring, has an extra input (for maybe doorcontact) and switch something with it too... bit expensive but does the job right.
@rualblas
Is this the marmitek s10??? Is the Elekhomica also not working than??
I only have used a marmitek sm10 marmitek, i don't know if de elekhomica version is different. maybe its a a marmitek\powerhouse in a other housing.
Gr Ruud
it's working fine with a relay and The contact setting
Gr Ruud
I use the KAKU doorbell. Just put a 12V AC relais between the normal trafo driven doorbell and the KAKU unit.
So far worked 100%
Willem-Bram
HS 2.0 / JvCADDX / SKYPE connector / RFXCOM / Moony / Mainlobby
So far worked 100%
Willem-Bram
I use a PSC01 (US version of the SM10) that I modified to 220V. Works perfectly with the 8V doorbell-transformer.
@glabbeek
Where did you get the relais on ac?? My local store doesn't have it.
And is the power ok, mostly the trafo's are 8v?? or 8-12v?
They sell it at RS Components BV
http://nl.rs-online.com/web/search/sear ... ind+my4+ac
6,97 incl shipping and BTW
Other than is it's very hard to find.
Willem-Bram
Willem-Bram
Re: doorbell and with ds10a possible?
glabbeek wrote:They sell it at RS Components BV
Willem-Bram
Hi in my other topic (Doorbell ACDB-6500BC) I was advised contact you through PM. Did not get any response, so I try here. I would like to get your solution working for me as well, but I am not an electrician so need some more detailed info how to get this working. I have some pictures form my existing doorbell attached. I need to keep that in place (and working). So please help me out. Thanks. (which relais do I need to order form the mentioned site?).
