I was wandering what cams do u use to brandcast and what program do you use to brandcast because I want to do what ur doing but I don't no how do u have a email address could u email me
I only have a normal web cam is that ok
chaypell
Which Webcam Program
Moderator: Esteban
Hi Chaypell
Just read the topics in this group and specially this topic http://www.domoticaforum.eu/topic.asp?TOPIC_ID=59
I think you will find all the information you need. I use a Videoserver from AXIS called the 241Q which can hold up to to 4 camera's as explained in the above topic.
regards Pieter
regards Pieter
If you just have a normal webcam connected by USB or something like that. You can download software like webcamxp www.webcamxp.com. With this program you can set up a webserver and share the camera over the internet.
- Starting Member
Hi I use ActiveWebcam from www.pysoft.com - supports a lot of different cameras and has own webserver capability built-in - been working fine for a couple of years. It also does motion detection recording and all the normal things you would expect.
I actually use wireless IP cameras similar to these:- http://www.neu-fusion.com/PHPWeb/Produc ... DforShow=9
The ActiveWebCam software runs on the same PC as my HomeSeer system.
ok thanks how ofter do u use ur cam
chaypell
chaypell
how ofter do u use ur cam jhon
chaypell
chaypell
I think we don't understand the question?
We use it every day
We use it every day
jhon what ur web cam address so i can see it
chaypell
chaypell
