Oregon Scientific BMI Scales with Remote Monitor
Moderator: b_weijenberg
http://www.oarsport.co.uk/products/oregon_scales.php
@Bert
How about support for this one..
for the real geeks.
# Body Weight
# Body Fat Index (BFI) calculation
# Body Mass Index (BMI) calculation
Snelvuur
Post by Snelvuur »
price is also very nice..less than 100euro
Maybe Pieter can collect all the information for all the forum users...lol
If I check the protocol in RFXcom documentation then only the BWR102 is supported right. Perhaps Bert can upgrade to the other scale to, if somebody can lend him the new scale [:)] ? Look nicer and much more readings..... and we like readings[:D]
The scale is unlike the BWR102 depending on the extra LCD panel, so you need the panel (looks like?) I don't use the extra LCD panel for my BWR102 Weight scale.
I have the BWR102 Scale running now on the 433Mhz RFXcom receiver and its working perfect. In a short while I will put the scale online.
This is a preview picture
Every reading is logged in my database (MYSQL 5) I can see on the weight for which person the reading is. I just look at the reading and select a record from the database which is X kg close to the reading.
<i>SELECT * FROM weightscale Where waarde >= '" & b_waarde & "' AND waarde <= '" & e_waarde & "' ORDER BY id DESC LIMIT 1"</i>
Pieter Knuvers
I'd really like this scale with BMI and BFI!
So Bert, if you think this can be done, let me know and i'll buy one and bring it to you.
Robert.
And I will be the second one if you can also build the charts for Homeseer...:)
Pieter do they have no GYM at your place..[:D]
Yep,Pieter is in the "danger" zone, his bar is red...[:D]
[:I] When I first made the chart my weightbar came automatic in green. I thought mmhh that's not so good, why is the chart not intelligent? You know the guy's on the forum will comment on that [:)]
So I had to Order the table on weight and by luck I came out in red, the color it should be. According BMI and still not in the red zone but I have to watch it now which I can realtime! Of to work now I'm already late.
b_weijenberg
Post by b_weijenberg »
Robert,
You are welcome with that type of scale and your receiver module.
I will give it a try to implement that scale too. I hope/think the protocol is not much different.
Bert
Binkey and Chak wants to buy the scale as well so there are enough volunteers :-)
Snelvuur
Post by Snelvuur »
Ok, so who will send one to bert. We can always order one, let it send to bert. Then if it works (or not) we can take it back?
I'll order one in the evening!
Snelvuur
Post by Snelvuur »
Your going to send it to bert then? Best is to do it directly to his place i presume?
I'm in contact with http://www.futurumshop.nl/
They will send an message at the end of they about availability and price.
Before we buy more..best is we wait what Bert can do...if this model is not going to work then I will go for the other one.
Snelvuur
Post by Snelvuur »
Yes agreed, although i would think that at least weight should be possible.
