two houses, one control?
Forum about PLCBUS devices & software.
Moderator: Digit
Postby tompo » Mon Aug 24, 2009 11:44 pm
Hi there,
My girlfriend and I have two houses next to each other. In the first house I have a domotica system running, using PLCbus and homeseer. We would like to extend this to both houses.
Connecting the electrical circuits from both houses directly is not an option :(
Is there anyone who has an idea how to connect two houses using PLCbus and homeseer?
tompo
Postby TANE » Tue Aug 25, 2009 12:20 am
you can use a Rf receiver for the second house
or just use another protocol like zwave/plugwise/kaku
http://twitter.com/Chak64%20My%20Domotica%20Log%20www.tane.nl/domotica/hardware.html<i> My Domotica Hardware Software</i></font id="size1">
Postby Rene » Tue Aug 25, 2009 8:41 am
Is it possible to attach two PLCBus PC interfaces to Homeseer in parallel? If it is, connect one PC interface to a Belkin USB network hub and make this available over Internet (taking security measures offcourse). You can then connect Homeseer to the second PLCBus interface over the Internet.
Postby tompo » Tue Aug 25, 2009 9:04 pm
Hi Chak and Rene,
Thanks for the fast response.
I thought of a RF receiver in the other house but I couldn't find a RF transmitter that sends out the signals comming from homeseer. Unless I overlooked something, a RF receiver in the other house would only be a solution when using RF remote controls.
Using another protocol could be a solution but I really like the PLCbus protocol. Fast and devices are not that expensive. And I really like the crystal panel switches which I think cann't be used with an other protocol.
Allthough the PLCbus interface uses an USB connector, the plugin in homeseer uses a serial port. This is solved by a USB to serial driver you have to install in widows.
Connecting two PLCbus interfaces would be a nice solution. But I don't think it is going to work. The PLCbus plugin in homeseer can only address one serial port. I don't see a possibility to install the PLCbus plugin twice.
tompo
Postby kevinlo » Wed Aug 26, 2009 9:21 pm
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by tompo</i>
<br />Hi Chak and Rene,
Hello Tompo ,
You can use RFXCOM 's RF Transmitters + Homeseer plug-in for send out RF command in homeseer.
http://www.rfxcom.com/transmitters.htm
http://www.rfxcom.com/downloads.htm
Then in the second house use PLCBUS-4022 for receive that RF signal for control send house's PLCBUS device. But you will lose the two-way communication function if you use RF only.
Can your first house's PLCBUS powerline signal reach second house ?
Kevin Lo
kevinlo
Return to PLCBUS Forum
cron
