I used components from http://www.embeddeddatasystems.com to create real time charts on our site. http://www.TheSelfReliantHome.com
Basically you read the device values from a web page and store the data in a database. Then I use a windows service and send the data to the site via windows communication foundation.
Online Temperature and Humidity Devices
Hi dkelley,
I use a web-server thermometer from Hygrosens.
Works great.
64 temperatures, simply with DS1820
See:
64-channel:
http://shop.hygrosens.com/Messsysteme-a ... naele.html
Or 1 channel:
http://shop.hygrosens.com/Messsysteme-a ... apter.html
Kind regards, Verkenner
Works great.
See:
64-channel:
Or 1 channel:
- Starting Member
Hi Verkenner,
Could you provide a principal sketch(drawing) of the network layout.
My question is also what kind of temperature transmitters are you using and what is the maximium distance to the weberver you can use?
Thanks in advance.
Arno
Thanks in advance.
Arno
