Looking for devices with Network ports
look at www.dynatronics.nl this is a (Dutch) supplier which has just started selling the Poseidon Ethernet controllers in the Netherlands.
- Starting Member
- Contact:
The WAGO 750-841 Ethernet TCP/IP programmable Feldbus-Controller.
I use this PLC to control my house.
http://www.wiredhouse.nl
www.wiredhouse.nl
www.wiredhouse.nl
lanbox-LCE DMX controller (can also be used stand-alone)
http://www.lanbox.com/products/LCEDataSheet.html
FCS-1030V2 10/100Mbps Network Camera
http://www.levelone.eu/products3.php?idu=7004&id=2077
Media player: Popcorn Hour A-100
See quick review: http://www.domoticaforum.eu/topic.asp?TOPIC_ID=918
Cheers
DJ
Cheers
DJ
Here's my list:
<ul>
<li>Intel Core2 Duo E8200 Windows 2008 server</li>
<li> Intel Celeron 300 FC2 server</li>
<li> HP Color LJ 2605dn</li>
<li> Convision V200 video-server</li>
<li> Acer Aspire T7200 Vista HP laptop</li>
<li> Acer Aspire 3000 XPH laptop</li>
<li> Homebuilt AMD Thunderbird XPP PC</li>
<li> Homebuilt Intel P4 3,2 GHz XPP PC</li>
<li> Homebuilt AMD Geode XPP PC</li>
<li> Homebuilt AMD Athlon 2000 W2K server</li>
<li> Homebuilt AMD Athlon 2400 W2K server</li>
<li> Homebuilt AMD Athlon 64 X2 3800+ EE SFF Windows 2008 server</li>
<li> Pinnacle Showcenter 1000</li>
<li> RFXCOM LAN-Interface (2x)</li>
<li> Linksys WAP54G access point</li>
<li> Sweex access point</li>
<li> 3Com 5-port 1 Gbps switch</li>
<li> 3Com 16-port 100 Mbps switch</li>
<li> Thomson Speedtouch 510i</li>
<li> Lava Ether-Serial Link 2-DB9</li>
<li> Sollae EZL-200F Ethernet-RS232 converter</li>
<li> HA7Net 1-Wire Bus Master</li>
<li> Philips Pronto TSU9600</li>
<li> iPod Touch 8GB</li>
<li> Conceptronic 8-port 100 Mbps switch</li>
</ul>
Just finished Ethernet-enabling everything USB/Serial tonight[:)]
<ul>
</ul>
Yes?
Robert
you need to update your list
Gone:
* Intel Celeron 300 FC2 server
* Acer Aspire 3000 XPH laptop
* Homebuilt AMD Thunderbird XPP PC
* Homebuilt AMD Athlon 2000 W2K server
* Homebuilt AMD Athlon 2400 W2K server
* Convision V200 video-server
* Sweex access point
* 3Com 16-port 100 Mbps switch
* Thomson Speedtouch 510i
Added:
* Synology DS109
* Axis 206
* Asus TOP
* Asus R2H
* 3 * 8 Port D-Link 1080D
* Sollae EZL-400S
* Linksys WAP54G access point
* Belkin USB LAN
* Fritz!Box FON 7170
* 3 * Devolo Powerline Ethernet adapters
* IRTrans LAN
Added:
* Synology DS109
* Axis 206
* Asus TOP
* Asus R2H
* Sollae EZL-400S
* Belkin USB LAN
* IRTrans LAN
