Fixed ignoring call information
In rare cases the Fritz!Box can send multiple lines of call information in one go.
Only the first line was processed, the rest was ignored.
Special thanks to sddroog for providing the info that enabled me to fix this.
Experimental: Caller Information
By adding this line to your FBF.INI:
CallerInfo=True
Removing this line again will disable it; the ini-file is checked with every phone-call so no need to restart anything after editing the ini file.
This is experimental! So don't complain, you've been warned. I've tested it here this evening and it worked ok.
Plug-In Script Command (Alexander )
Defined as: Public Function AnonymousDisplay() As String
This function will return the "Display anonymous Caller as" Plug-In setting.
You can find the latest version of the Plug-In here
