PH7208 - PowerHorn Siren
nieuw 35 euro excl verzend
http://www.eurox10.com/Product/Security ... PH7208.htm
PowerHorn is used as an additional audio alarm unit for use with the Home Security System which gives an additional independent 110 decibel sound output when the security system is triggered. The PowerHorn will only trip a few seconds later after the alarm trips. It counts the sequence transmitted to flash lights connected to Lamp Modules after the lights have flashed 4 or 5 times. This prevents it from being accidentally tripped from any other X10 controller.
You can also trip the PowerHorn from any other X10 controller, which is useful in panic situations.
It can be added anywhere around the home; nobody wants to hang around when one of these activate.
Technical information
Power: 230V, 50 Hz
Current: <= 20 mA capacitive
Sound Output: 110 dB
Signal Sensitivity: 15 mVpp min 50 mVpp max at 120 kHz
Input Impedance: <= 55 ohm (L-N) at 12 kHz
Temperature: -10°C to 50°C (operation); - 20°C to 70°C (storage)
Dimensions: 53 x 123 x 33 mm
EMC Emission: according to EN 80081-1
EMC Immunity: according to EN 680082-1
Electrical Safety: according to EN 60950 and EN 60065
X10 powerhorn PH7208
Jump to
- Forum matters
- ↳ News Forum
- Hardware Forum (English)
- ↳ Z-Wave Forum
- ↳ Fibaro
- ↳ Plugwise Forum
- ↳ Gadgets Forum
- ↳ Visonic Alarm systems
- ↳ LEDS, DMX & Lights Forum
- ↳ Opentherm Gateway Forum
- ↳ 1-Wire Forum
- ↳ PLCBUS Forum
- ↳ Smart Metering Forum
- ↳ ZigBee Forum
- ↳ Toon news and information
- ↳ Manuals/tutorials
- ↳ Toon Apps
- ↳ Toon Rooting
- ↳ Toon Hardware
- ↳ Toon Firmware
- ↳ Toon external control
- ↳ Toon miscellaneous
- ↳ Toon software development
- Software Forum (English)
- ↳ Announcements & News
- ↳ Linux Forum
- ↳ Windows Forum
- ↳ DomotiGa Forum
- ↳ OpenHAB Forum
- ↳ MQTT & Node.js
- Projects Forum (English)
- ↳ Home Automation Projects
- ↳ Bwired Forum
- ↳ Homeseer algemeen Forum
- ↳ Homeseer Scripts Forum
- ↳ Homeseer HStouch Forum
- ↳ Homeseer Plugins Forum
- Other (English)
- ↳ Off Topic
- ↳ Downloads & Links Forum
- ↳ Domoticaboek Heino Peters
- ↳ Dealers Corner
- ↳ Test
