IP Cam on Pronto
Forum about hardware/software for the Philips Pronto TSU9600 and other remotes.
ralhop
IP Cam on Pronto
Post by ralhop »
I can't get my IPcam get to work on my pronto.
I use a instar ip camera and I can log in with
http://192.168.2.150/snapshot.cgi?user= ... d=roland25
I use the IPCams v9600 script.
can someone help me to get it work
Ralph
ralhop
Re: IP Cam on Pronto
Post by ralhop »
of cause I've been reading these topics bofore I was posting mine ,but I'm nog good in scripting. so I was hoping that someone can help me with an easy solution.
best regards ralph
Ralph
Try this one:
var socket = new TCPSocket();
var receivedData = "";
socket.onConnect = function() {
System.print ("TCP-IP Connected");
socket.write("GET /snapshot.cgi?user=admin&pwd=roland25" + " HTTP/1.1\r\n\r\n");
socket.onData = function() {
receivedData += socket.read();
System.print ("Tcpip Data Received:"+ receivedData);
socket.onIOError = function (x) {
GUI.widget("panel").label = "IOError " + x;
System.print ("Tcp Error:"+ x);
socket.onClose = function () {
// remove the HTTP info from received data
var imageStartIndex = receivedData.indexOf("\r\n\r\n");
var bitmapData = receivedData.substring(imageStartIndex+4);
// display the image
var MyImage = new Image(bitmapData);
GUI.widget("panel").setImage(MyImage);
socket.connect("192.168.2.150", 80, 6000);
ralhop
Post by ralhop »
I'm new in Prontoedit so where do I put this script?
grz Ralph
Ralph
sorry cant help you right now
at the moment I have not installed the Pronto software.
Read the stuff first, because if you don't' understand the basic stuff it will be very hard to understand the complete package.
Programming the pronto is no boy stuff :wink:
denniseckhart
Post by denniseckhart »
ralhop wrote:I'm new in Prontoedit so where do I put this script?
grz Ralph
Ralhop, did you made any progress? bacause i am having problems likewise !
ralhop
Post by ralhop »
I've sold my pronto because I bought an Ipad to control my domotica.
Ralph
Return to “Philips Pronto (TSU9600), IRtrans and other remotes”
