CheckTrigger in Events module
Moderator: RDNZL
hhg
Post by hhg »
Hi
I had some troubles getting my Oregon sensor to control the bathroom fan when I noticed this in the debug log:
2010/09/18 11:27:06 [Events] Check trigger 67 > 63 = False
2010/09/18 11:27:06 [Events] Check trigger 67 < 63 = False
Well, turns out to be line 343 that failed:
IF IsDigit(sValue) AND IF IsDigit(sCond) = FALSE THEN
So I replaced that block with the one from CheckCondition:
CASE ">"
	      sValue = "" & sValue ' be sure it are strings
	      sCond = "" & sCond
	      IF IsDigit(sValue) AND IsDigit(sCond) THEN
	        IF Val(sValue) > Val(sCond) THEN bReturn = TRUE
	      ENDIF
Do the same for > an it works - And then I realised that CheckTrigger and CheckCondition does the same, and are identical except for the log messages, so in the end, I just replaced the call in line line 218 in CheckDeviceChangeEvent with a call of CheckCondition:
IF NOT CheckCondition(sValue, rResult["triggers.param3"], rResult["triggers.param4"]) THEN CONTINUE
And then deleting the CheckTrigger procedure
/hhg
RDNZL
Re: CheckTrigger in Events module
Post by RDNZL »
Thanks, I have added your changes and deleted the CheckTrigger() code.
Regards, Ron.
RDNZL
Post by RDNZL »
I have added numerous fixes to events code and editors again in revision 420.
I now finally know why older code failed to work, DoEvent() and RunActions() got a result set as argument, that set included all records of the same type of trigger but without additional checks for value and field, so they also run all triggers and actions that where not meeting the conditions. 8)
And although it looked very clean it was not efficient, since some sql queries where done over and over again in different routines.
Now I just pass the needed value(s) directly so extra queries are not needed anymore.
Regards, Ron.
Return to “DomotiGa Forum”
