Pachube's not working. Keep on getting "Error page not found while uploading sensor data to Pachube!"
Have checked the API key. Also on debug log I get http/1.1 404 Not Found
Can anyone help me?
thanks,
m
Pachube not working
Moderator: RDNZL
- Member
Re: Pachube not working
I've enabled auto-feeds after the manual upload stopped wrking.
If you have a webserver with the domotiga-webclient(the original one) you can use that for pachube to automatically pull in the data.
Then register a feed @ pachube where you point to your webserver like this:
http://<user:pass@webserver>/<domotiga>/?setview=pachube
The sensors you've enabled to send data should show up after verifying the url.
Good luck,
Good luck,
