VPN an Vmware
Re: VPN an Vmware
i have resend the e-mail without digital id. if it doen'st work i'll resend it to pieter.
Nice video but it's unwise to have multiple vpn client on 1 windows installiotion that's why i used safenet client.
silly of me, the pdf files are a lot smaller
Oeps no pdf allowed
** edwin **
Re: VPN an Vmware
thanks for the files..
trying the Iphone connection using
http://www.gogogad.de/2010/06/16/howto- ... tzbox.html
Re: VPN an Vmware
did you get the files alright? Most importend are the pdf files and the readme.txt file. Installers can be found at the locations mentioned in the readme file
** edwin **
Re: VPN an Vmware
This link shows an IPSEC tunnel. If that is the case i will use it also and hopefully they use the standard ports.TANE wrote:thanks for the files..
Alexander
Re: VPN an Vmware
there is Ipsec support on the Iphone.
even the cisco ipsec works wel using RSA keys.
still trying to connect...
Re: VPN an Vmware
I have managed to make a VPN connection from the Iphone to the Fritzbox
using the build in IPSec client.
Next step is also make possible to connect using the same VPN from the PC.
VPN from the PC is described in the available docu.
