Is it possible to use Jablotron (868 Mhz) sensors / detectors with a RFX receiver in combination with a Visonic receive module?
Is only the transmit freq (868 Mhz) important or also the used protocol?
Jablotron sensors / detectors
Moderator: b_weijenberg
Re: Jablotron sensors / detectors
Both indeed... Only protocols that are listed are supported.labtec wrote:Is only the transmit freq (868 Mhz) important or also the used protocol?
Alexander
