Is there anyone knows if there is the next product to get:
A combined microphone / speaker that can be used over the network (by cable or WiFi) to for example the HomeSeer server?
I want to use in a few rooms only a speaker and microphone that I have to work over the network.
I have found already solution like the Speaker Anywehere 200 but this one has no mic.
Have some one a idea?
Grtz,
Network Loudspeaker and Mic
__________________
Network Loudspeaker and Mic via Allegato
Dieuwert-Jebbe, did you consider this?
From drMacchi: http://www.domoticaforum.eu/viewtopic.p ... ilit=audio
http://www.futurashop.it/allegato/7100- ... =Controlli remoti e telefonia&L1=Scatole di montaggio&L3=Networking&cd=7100%2DFT859M&nVt=&d=72,00
http://www.futurashop.it/carrello_sql/p ... FT859M.jpg
Not very cheap but a nice device.
Verkenner
Verkenner
Best regards, Verkenner
Re: Network Loudspeaker and Mic
@verkenner, this it a very nice solution only a little bit to expensive (i need 2 of them to do the job).
I think i hold it for now with a simple wireless speaker system and maybe in the future i found a sollution for the mic.
__________________
I bought a couple of them , and will install in next days (let's hope). I'll forward News . Ciao
Show the results later!
good luck....
good luck....
Ok guys, please go to my original post http://www.domoticaforum.eu/viewtopic.p ... ilit=audio for results
DJdive, and this?
http://www.smarthome.com/97311/C-Crane- ... ack/p.aspx
Or find something in this open box: http://www.smarthome.com/clearance.asp?src=HML11RA14
Good luck !
Verkenner
Good luck !
Verkenner
Hi Verkenner,
yes something like that.
I have in the past days look for a good solution and want to try the next:
- Connect a USB/LAN server to my HS network link
- Insert a USB Soundcard to connect it with a small speaker and mic link
And i think it must be working, when i have install it i will give my results.
Grtz,
Grtz,
__________________
Hi D-J,
If you want it wireless you can consider this cheap solution:
http://www.samenkopen.net/action_product/52762/775951
Manual: http://www.djrobke.com/images/vap11manual.pdf
Regards, Vrkenner
Regards, Vrkenner
