RFXLAN Flash update
Moderator: b_weijenberg
RFXLAN Flash update
Hi, This week I received the RFXLAN Tranceiver from RFXCOM. Since I want to use it with Homeseer through Ethernet, I was advised by RFXCOM to flash the device with the TCP firmware instead of the xPL wich was installed by default. So I attached the device with usb cable to the PC and followed the instructions form the CD. So far so good the Driver was installed. Next step open the RFXFlash.exe. Now it should be possible connect to the device. But no connection will be made. Tried alle possible settings (different com port, ect.) no go. Tried another pc but same again. Anyone experienced this problem? Is the device broken? Please advice.
- b_weijenberg
- Forum Moderator
Re: RFXLAN Flash update
Use the rfxlan.inf on the CD to install the correct Windows driver.
Please contact support rfxcom if still problems.
i flash my RFXlan twwo weeks ago,
I follow the instruction but windows give "com5" to my rfxlan in usb mode. The software look for com1, com2, Com3, Com4; So i change in window and force it to com2. It was possible to flash after .
im using windows seven.
regards
regards
nicolas
regards
regards
nicolas
- b_weijenberg
- Forum Moderator
During initialization after startup of RFXflash it will search for all available and not used COM ports. These ports are in the drop down box.
First plug-in the RFXLAN USB than start RFXflash so that it can find the RFXLAN.
