Looking for beta testers to test HouseAgent
Introduce home automation related software here.....
deraaij
Re: Looking for beta testers to test HouseAgent
Post by deraaij »
Mdamen wrote:I'm proud to announce that the first beta version of HouseAgent is available here for testers: http://www.houseagent.nl/forum/viewtopic.php?f=4&t=16
Congratulations!
Mark
Noel
Post by Noel »
Not sure if βeta testing is still open, but if so I would love to have a go at it.
Mdamen
Post by Mdamen »
No problem, just register on the forum and I will give you beta access!
Noel
Post by Noel »
Mdamen wrote:No problem, just register on the forum and I will give you beta access!
Done... I'm "guest" on your forum :-)
mishoboss
Post by mishoboss »
Seems to be really good start. Do you plan KNX integration?
CLC
Post by CLC »
New beta tester on houseagent forum.
Mdamen
Post by Mdamen »
@CLC, Noel: gave you guys access.
@mishoboss: there are no concrete plans for that yet, though it's a big upcoming market. I have zero experience with KNX so it would be nice if someone would pick it up.
Alexander
Post by Alexander »
It would be a big plus plus plus if the system would have a visual/graphical flow chart in scenes. I'm familar with the VoIP PBX Swyx (http://www.google.nl/imgres?q=swyx+grap ... 80&bih=660) which has one and Vordel (http://www.google.nl/imgres?q=vordel+fl ... 80&bih=660). The examples have nothing to do with HA, but the idea is the same.
Would this be possible? Than you would not have to have those standard way of options to create a event, based on pre defined options. (In Swyx and Vordel you have also the option, if the predefined blocks don't help, to use a scripting block (in which you put the scripts that must run.)
Alexander
Mdamen
Post by Mdamen »
That's a great idea, thinking of events as flow charts!
I found a javascript library that does some of the work: http://neyric.github.com/wireit/
An example: http://neyric.github.com/wireit/plugins ... index.html
Noel
Post by Noel »
Anyone here coding a X10 plugin for HouseAgent?
keeslamper
Post by keeslamper »
Are you still looking for testers? I want to test with Z-wave if you want. I'm looking for software to try, I'm a newbie!
turboproc
Post by turboproc »
I would be pleased to contribute by testing. Please provide my with the latest Jeenode plugin. I've the impression that the plugin at GitHub is not aligned anymore with the API in the latest version of HouseAgent. That allows we to start testing with the Jeenodes that shoud arrive next week. Furthermore I should investigate what's needed to simply include the YouLess sensor into HouseAgent.
I'l be running HouseAgent in a Linux Gentoo environment. That part of the installation has in fact been completed without to much trouble.
Return to “Announcements & News”
