Yes at last, time for the visonic.
So i made a plan for where to place magnet's, infrared & smoke detectors. Hm, i ended up with a list longer as 30. If intreped the manual correct i'm unable to connect more then 28 wireless magnet's/infrared etc. Am i missing something or do i have to limit the amount of detector's?
what if you exceed the 28 (30) detectors?
Moderators: Rene, Willem4ever
** edwin **
Re: what if you exceed the 28 (30) detectors?
Edwin,
Not sure but I think you can use a Visonic expansion box like the MCR-304 or MCR-308. See beveiligingswinkel.nl/portals/0/product ... cr-308.pdf.
This will cost you one hardwired zone. Probably a shop can tell you or confirm if it's possible.
Mark
Mark
i don't think this will work. it is ment to connect 8 wireless detector's to 8 corresponding wired zone connection's. Only thing i would archive is to change zone 29&30 from wired to wireless. But in a effort to optimize the zone's i'm already using the wired zone's
** edwin **
