does anybody use Danfoss RA radiator valves in Homeseer, if yes, where to buy the ("old") RA-thermostats ?
Does it work perfect ?
HS screenshots aviable ?
Regards, Fischi
Homeseer /Danfoss RA radiator valves
Moderator: Ruud
Re: Homeseer /Danfoss RA radiator valves
Good post! Winter is coming and i an curious if Homeseer worked
out their problems with Danfoss!
- Member
I've two of the 'old' ones but can't use because my radiators use on/off buttons no thermostatic...
The old ones works fine in Homeseer.
Don't forget to optimize the network manually with battery powered devices.
Off (moon)
Thermostat Value Set set to Permanent Setback On
On (Son)
Thermostat Climate Control Schedule Value Set set to Setback Off
The On/Off can be a bit confusing.
Best is to create a event and just simple use Off or On with the values above,
Off (moon)
On (Son)
If somebody is interested, I still have two of them laying somewhere in my domotica stock (never installled)...
Weet iemand waar ik deze 'oude' radiator kranen nog te verkrijgen zijn? .. neem aan dat er nog geen alternatieve radiatorkranen zijn die werken met homeseer?
- Member
Ik heb er twee liggen.
Kees, wat vraag je voor je 2 kranen? Heb wellicht interssen om e.e.a. eens te proberen...
Synology DS213+ / Domoticz / RFX Transceiver-e
Just to be clear... The Old "valves" only work with an On and Off function, correct? They do not adjust to a certain temperature? The sun and moon function is not totally clear to me...
