Now i`m using HomeSeer and would like to achieve the same. I have found the following script
http://www.iease.nl/2012/02/15/homeseer-mysql-2-2/
But i get the following error
6-11-2012 15:14:15 - Error - Script compile error: Het type MySqlConnection is niet gedefinieerd.on line 21
Imports System.Data
Imports MySql.Data.MySqlClient
Dim Public ID As String = "statusCallBack.vb"
Sub checkStatus(ByVal aParm as Object)
dim stat, hc, dc, hdc,refID, sName as String
Dim conn As MySqlConnection
Dim myCommand As New MySqlCommand
Dim varDate as String
Dim varTime as String
Dim varDeviceName as String
Dim varDeviceCode as String
'PLACE THIS STATEMENT IN YOUR STARTUP SCRIPT
' hs.RegisterStatusChangeCB "statusCallBack.vb","checkStatus"
hc = aParm(0)
dc = aParm(1)
stat = aParm(2)
refID = aParm(3)
hdc = hc & dc
Dim device
Dim dn
Dim type as String
Dim tijd
tijd = Datepart("yyyy",Now()) & "-" & Right("0" & DatePart("m",Now()),2) & "-" & Right("0" & DatePart("d",Now()),2) & " " & Right("0" & DatePart("h",Now()),2) & ":" & Right("0" & DatePart("n",Now()),2) & ":" & Right("0" & DatePart("s",Now()),2)
device = hs.GetDeviceByRef(refID)
dn = device.name
'Detect type of device
Select Case (hc)
Case "#"
type = "temp"
Case "$"
type = "minmax"
Case "["
type = "ping"
Case "A"
type = "Schakelaar"
Case "C"
type = "Schakelaar"
Case "H"
type = "Schakelaar"
Case "K"
type = "Schakelaar"
Case "P"
type = "Schakelaar"
Case "R"
type = "Remeha Calenta"
Case "W"
type = "Weer"
Case "Z"
type = "Server"
Case "_"
type = "Plugwise"
End Select
'hs.writelog(ID,"House Code: " & hc & " Device Code " & dc & " Status: " & stat & " Device Value: " & hs.DeviceValue(hdc) & " Device String: " & hs.DeviceString(hdc) & " Name: " & dn & " Type: " & type & " Time: " & tijd)
conn = New MySqlConnection()
conn.ConnectionString = "server=localhost; user id=xxxxxxx; password=xxxxxxxx; database=HomeSeerDB"
Try
conn.Open()
'hs.writelog ("mySQL", "Connection Opened Successfully!")
myCommand.CommandText = "INSERT INTO tbldevices (hc,devicename,type,dc,value,status,ts)" & " VALUES ('" & hc & "','" & dn & "','" & type & "','" & dc & "','" & hs.DeviceValue(hdc) & "','" & stat & "','" & tijd & "')"
myCommand.Connection = conn
myCommand.ExecuteNonQuery()
'hs.writelog ("mySQL", "Logged to database: " & varDeviceName & ", " & varDeviceCode & ", " & iStatus)
conn.Close()
Catch myerror As MySqlException
hs.writelog ("mySQL", "Error Connecting to Database: " & myerror.Message)
End Try
End Sub
C:\Program Files\HomeSeer HS2\Scripts\Startup.txt
De volgende regel toegevoegd net boven End Sub
