Have an Fibaro FGS-221 with two lights attached, I can switch the first one with HStouch, Homeseer and the wall-switch. The second light is'nt reacting when switchting with HSTouch or Homeseer and when I use the wall-switch the light sometimes blinks once.
Any idea how this can happen? How can I reset the Fibaro device? Can't see any strange behavior in the Homeseer logging.
Fibaro FGS-221 freaked out
Re: Fibaro FGS-221 freaked out
On a strange way is the device now working normal again.
New behavior, when light 1 is switched on i can't switch light 2, first have to turn 1 off....
Try swapping both switches/lights to see if it is a wiring issue or a defective module
