Greenwave powernode 6
Moderator: RDNZL
I'm currently investigating Domotiga (finally )
BUT i have some issues with the powernode 6. If I add that device to domotiga I only see one device instead of 7 (at least 7 in homeseer).
What am i doing wrong?
Re: Greenwave powernode 6
What version DomotiGa / OpenZwave are you using?
I am running the Powernode 6 without any problems.
in your wrappers/domozwave directory there should be a file zwcfg*.xml
In that file you should find a node with Manufacturer name GreenWave, here's (part of) mine for example:
<Node id="2" name="" location="" basic="4" generic="16" specific="1" typ
e="Binary Power Switch" listening="true" frequentListening="false" beaming="true
" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
<Manufacturer id="0099" name="GreenWave">
<Product type="0003" id="0004" name="PowerNode 6 port" />
</Manufacturer>
<CommandClasses>
<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="5" mapping="37">
<Instance index="1" endpoint="1" />
<Instance index="2" endpoint="2" />
<Instance index="3" endpoint="3" />
<Instance index="4" endpoint="4" />
<Instance index="5" endpoint="5" />
<Instance index="6" endpoint="6" />
As you can see, mine detects 6 instances for that node.
Can you attach your zwcfg*.xml file, or check how your GreenWave node gets detected?
If you tried running with an older version of openz-wave,you can try deleting the file, in which case a discovery of the entire Z-Wave network is done again.
</Manufacturer>
<CommandClasses>
I don't have a zwcfg*.xml file in the domozwave directory.
If i look at the Zwave manager i see all the Z-wave devices including the Powernode 6 (greenwave) on ID 44
Little site-step, i took the aeonlabs stick from a working Homeseer environment. So everything is connected already to the stick.
I haven't created a device yet.
--Edit
I was too quick.
After about 30 minutes i saw a log entry (zwave interface is fully initialized)
And here we are, an XML file:
AND all ports are available!!
Wowie, up to the next journey, Jeenodes
--Edit
I was too quick.
<Node id="44" name="" location="" basic="4" generic="16" specific="1" type="Binary Power Switch" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
</Manufacturer>
<CommandClasses>
</CommandClass>
Good to see it's working!
Jeenodes are supported in DomotiGa, but not everything yet.
Currently only the default roomnode format is supported.
Is that with a special sketch or something? Or just the default jeelink / jeenode sketch?
Defaul RoomNode sketch is supported.
@vanisher:
If it takes 30 minutes before the the open-zwave is fully initialized, can you check which revision you're running? With r640+ this should be fast - within a few minutes max (or else some devices not always respond properly)
ps. the zwcfg*xml will only be created/updated AFTER it is fully initialized. This is a behavior of open-zwave, not of DomotiGa.
Alex,
DomotiGa 1.0.003
OpenZwave Revision: 643
Currently everything is discovered, but the powernodes are not updating the watt / KWh stats.
DomotiGa 1.0.003
You need to poll for the values, because they aren't automatically updated. Check the Z-Wave settings and enable "Poll listening" devices, an internal of 10 minutes (*/10 * * * *) is a good start.
ps. can you also attach the zwcfg*xml & OZW_Log.txt after it fully initialized, because it should take <2 minutes to complete. Then i will have a look if it is 1 specific device, because your open-zwave is up-to-date.
Yes!
Z-Wave is working, polling is working i get new values.. so that (for me) mystery is fixed.
Another mystery started:
I enabled rrdtool
I enabled graphs on a device. the logfile says that the <id>.rrd is created.. but nothing in the rrd directory.
Edit: Hmz, you have to fill in a type for every value.
Which type do you need to graph an on / off status?
I enabled rrdtool
- Member
I am also new to domotiga, but did got the powernode 6 added. I have added the overall on/off switch and meter as a device now, but how do you add every single switch? Do you add the value of the instance at the "Node ID". So node 7 instance 2 is 7:2?
Umbuntu: 12.04 x86
Domotiga: 1.0.003 (Gambas3 version)
OpenZwave: 643
I found the logfiles and somehow it says it can't find the specific instances.
2013/02/28 22:39:42 [Z-Wave] Got value changed notification for node 7 and instance 2 value1 changed to Off.
2013/02/28 22:39:42 [Devices] Device of type 'ZWAVE' with address '7:2' and interface 'Z-Wave Controller' not found!
2013/02/28 22:39:42 [Z-Wave] Got value changed notification for node 7 and instance 3 value1 changed to On.
2013/02/28 22:39:42 [Devices] Device of type 'ZWAVE' with address '7:3' and interface 'Z-Wave Controller' not found!
2013/02/28 22:39:42 [Z-Wave] Got value changed notification for node 7 and instance 4 value1 changed to On.
2013/02/28 22:39:42 [Devices] Device of type 'ZWAVE' with address '7:4' and interface 'Z-Wave Controller' not found!
2013/02/28 22:39:42 [Z-Wave] Got value changed notification for node 7 and instance 5 value1 changed to On.
2013/02/28 22:39:42 [Devices] Device of type 'ZWAVE' with address '7:5' and interface 'Z-Wave Controller' not found!
2013/02/28 22:39:42 [Z-Wave] Got value changed notification for node 7 and instance 6 value1 changed to Off.
2013/02/28 22:39:42 [Devices] Device of type 'ZWAVE' with address '7:6' and interface 'Z-Wave Controller' not found!
2013/02/28 22:39:42 [Z-Wave] Got value changed notification for node 7 and instance 1 value3 changed to 0.0838.
2013/02/28 22:39:42 [Z-Wave] Got value changed notification for node 7 and instance 1 value2 changed to 0.8.
2013/02/28 22:39:42 [Z-Wave] Got value changed notification for node 7 and instance 2 value3 changed to 0.3479.
2013/02/28 22:39:42 [Z-Wave] Got value changed notification for node 7 and instance 2 value2 changed to 0.0.
2013/02/28 22:39:42 [Z-Wave] Got value changed notification for node 7 and instance 3 value3 changed to 2.8328.
2013/02/28 22:39:42 [Z-Wave] Got value changed notification for node 7 and instance 3 value2 changed to 0.2.
2013/02/28 22:39:42 [Z-Wave] Got value changed notification for node 7 and instance 4 value3 changed to 2.5442.
2013/02/28 22:39:42 [Z-Wave] Got value changed notification for node 7 and instance 4 value2 changed to 18.4.
2013/02/28 22:39:42 [Z-Wave] Got value changed notification for node 7 and instance 5 value3 changed to 0.0279.
2013/02/28 22:39:42 [Z-Wave] Got value changed notification for node 7 and instance 5 value2 changed to 0.2.
2013/02/28 22:39:42 [Z-Wave] Got value changed notification for node 7 and instance 6 value3 changed to 0.2022.
2013/02/28 22:39:42 [Z-Wave] Got value changed notification for node 7 and instance 6 value2 changed to 0.0.
2013/02/28 22:39:43 [Z-Wave] Got value changed notification for node 8 and instance 1 value1 changed to On.
2013/02/28 22:39:43 [Z-Wave] Got value changed notification for node 8 and instance 2 value1 changed to Off.
2013/02/28 22:39:43 [Devices] Device of type 'ZWAVE' with address '8:2' and interface 'Z-Wave Controller' not found!
2013/02/28 22:39:43 [Z-Wave] Got value changed notification for node 8 and instance 3 value1 changed to On.
2013/02/28 22:39:43 [Devices] Device of type 'ZWAVE' with address '8:3' and interface 'Z-Wave Controller' not found!
2013/02/28 22:39:43 [Z-Wave] Got value changed notification for node 8 and instance 4 value1 changed to On.
2013/02/28 22:39:43 [Devices] Device of type 'ZWAVE' with address '8:4' and interface 'Z-Wave Controller' not found!
2013/02/28 22:39:43 [Z-Wave] Got value changed notification for node 8 and instance 5 value1 changed to On.
2013/02/28 22:39:43 [Devices] Device of type 'ZWAVE' with address '8:5' and interface 'Z-Wave Controller' not found!
2013/02/28 22:39:43 [Z-Wave] Got value changed notification for node 8 and instance 6 value1 changed to On.
2013/02/28 22:39:43 [Devices] Device of type 'ZWAVE' with address '8:6' and interface 'Z-Wave Controller' not found!
2013/02/28 22:39:43 [Z-Wave] Got value changed notification for node 8 and instance 1 value3 changed to 0.1072.
2013/02/28 22:39:43 [Z-Wave] Got value changed notification for node 8 and instance 1 value2 changed to 7.4.
2013/02/28 22:39:43 [Z-Wave] Got value changed notification for node 8 and instance 2 value3 changed to 0.0749.
2013/02/28 22:39:43 [Z-Wave] Got value changed notification for node 8 and instance 2 value2 changed to 0.0.
2013/02/28 22:39:43 [Z-Wave] Got value changed notification for node 8 and instance 3 value3 changed to 0.0000.
2013/02/28 22:39:43 [Z-Wave] Got value changed notification for node 8 and instance 3 value2 changed to 0.0.
2013/02/28 22:39:43 [Z-Wave] Got value changed notification for node 8 and instance 4 value3 changed to 0.0000.
2013/02/28 22:39:43 [Z-Wave] Got value changed notification for node 8 and instance 4 value2 changed to 0.0.
2013/02/28 22:39:43 [Z-Wave] Got value changed notification for node 8 and instance 5 value3 changed to 0.0000.
2013/02/28 22:39:44 [Z-Wave] Got value changed notification for node 8 and instance 5 value2 changed to 0.0.
2013/02/28 22:39:44 [Devices] Device of type 'ZWAVE' with address '8:5' and interface 'Z-Wave Controller' not found!
2013/02/28 22:39:44 [Z-Wave] Got value changed notification for node 8 and instance 6 value3 changed to 0.0000.
2013/02/28 22:39:44 [Devices] Device of type 'ZWAVE' with address '8:6' and interface 'Z-Wave Controller' not found!
2013/02/28 22:39:44 [Z-Wave] Got value changed notification for node 8 and instance 6 value2 changed to 0.0.
Umbuntu: 12.04 x86
OpenZwave: 643
Yes, for a PowerNode 6 you need to add 6 devices (addresses are):
7 - first socket
7:2 - second socket
7:3 - third socket
7:4 - fourth socket
7:5 - fifth socket
7:6 - sixth socket
The On/Off, Watt and kWh will be saved within 1 device for that specific socket information.
7 - first socket
7:2 - second socket
7:3 - third socket
7:4 - fourth socket
7:5 - fifth socket
7:6 - sixth socket
