Problem with RFXCom receiver / transmitter USB
Moderator: b_weijenberg
keeslamper
Post by keeslamper »
I've bought an second hands older model RFXCom receiver / transmitter.
I try to read the signals with RFreceiver, the only message I see in RFReceiver is from SLAVE...
Sometimes the message 'noise or unknown data package received: 234232awfa234 (<--example data!!) from SLAVE'
I've tried to reset with the 'Toggle Baud Rate' with no results.
I connect on the correct COM port and with 4800 baud.
My settings in RFreceiver are : COM5 = 4800-8-N-1. I select RFXCOM mode in RFreceiver.
Can somebody tell me what I'm doing wrong... I've followed the instructions from RFXCom.com but with no result!
Kees
b_weijenberg
Re: Problem with RFXCom receiver / transmitter USB
Post by b_weijenberg »
did you also try at 38400?
are you sure it is a Master receiver?
Does the receiver respond on the get receiver version?
keeslamper
Ik tried also 38400, it keeps scrolling very quick.
It saids noire or an unknown data packet received : numbers/letters (see a few rules from the scrolling window down in bold).
I'm not sure, how can I try? How can I reset?
A get receiver version gives :
Version: F7 FF
Hope you can help me!
Kees
DIGIMAX[8722]TY Digimax addr:1222 ID: 8722 No Set temp available Temp:8ºC | 46,4ºF Parity error on address/status SB:8
noise or an unknown data packet received: 1F0D53111F09
noise or an unknown data packet received: 0D091411
ATIPLUS[0]C Remote type= Unknown remote:4 Channel= 0 Even Command= 7
noise or an unknown data packet received: 1B2B43082325
noise or an unknown data packet received: 0B510B08
noise or an unknown data packet received: 0E043C08
noise or an unknown data packet received: 195B13291B25
HE Device=0341438 Unit=8 OFF
noise or an unknown data packet received: 350A1806091D0B0B98
noise or an unknown data packet received: 1209250E09
noise or an unknown data packet received: 09092B0E
noise or an unknown data packet received: 0E17080E
noise or an unknown data packet received: 2419111A21140B
noise or an unknown data packet received: 1D08280D1A14
noise or an unknown data packet received: 092D130D
noise or an unknown data packet received: 191405053914
HE Heater address=5 Reserved (unexpected)
keeslamper
I found in the manual the option to display baud-rate choice in the ini file! I searched for hours, now I'm connected @ 38400. It looks like it's working.
