Real-time online websites
- Starting Member
Hi Guys,
I'm in the process of creating my own automated house - i'm starting with energy usage.
You can check it out here: http://86.128.48.155/ <- Its all realtime to the minute!
You can go back in time and see every minutes usage throughout the year (although i've only recorded a couple of months so far!)
Im using a tecnique of recording the electricity usage from yourself bwired - using a simple LDR and a counter and reading the counts into a MySQL database ever minute, so far has about 100,000+ records [:p]
BTW: Click the Graph's bars to travel through time [:)]
Kris
Kris
Well, here's mine... you don't need a login to view things...
http://www.seawasp.com/seawasp.pl?script%23control
The "air purity" needs some calibration (as indeed does "gamma-ray")
Cheers, Steve
Cheers, Steve
Re: Real-time online websites
Cleaned up a bit, lots of sites where offline
any new ones to add?
Hai Pieter, got a new one for you just finished it: http://www.mcsdomotica.net.tf/
I would also like to be added to the BWired GoogleMaps service but haven't had the time to find out how, maybe you can help me be added quickly Pieter?
(Username & password = guest & guest)
Guest
Guest
status
its homeseer
Guest
status
its homeseer
Thanks Pieter, I've tested it localy so haven't noticed that yet. I have uploaded the XML to you server. with the XMLbwired plugin. No sensors yet but am working on that. Can you check if its okay? I haven't seen my entry on the google maps display yet.
You are in, should work now
needed to add username and password
I can't see it yet, is it possible that it takes a while?Bwired wrote:You are in should work now
Username en password; do you use just guest/guest? I will add them in the config screen than.
You've got your own darkroom?
I'm still very much starting at this although it may be a while before I attempt to do more.
There is a live text view of what I have done so far at http://pip.dulyn.co.uk/hometest
It needs a browser that supports websockets. I know the current versions of Google Chrome (Linux and Windows) and Firefox (Linux) work.
I've made some updates to my live page. When events occur, it now highlights the table rows for the devices/scripts that are affected for a couple of seconds. I think it makes it easier to see what's happening in real time.
I've spent the last few weeks reading about Smart Meters and stuff...
There are a lot of solutions to choose from. Got the components and finally got something online.
See it at: http://home.roelfloor.nl and read about it at (in dutch, though): http://www.roelfloor.nl
Looking good!
