i set up Fgr 221 for roller shutter. On/Off is working.
Is it possible to control it with dim function that it could be set to specific position ?
Here is my debug LOG:
013/05/25 11:13:59 [Z-Wave] Got value changed notification for node 7 and instance 1 value1 changed to Dim 239.
2013/05/25 11:14:33 [Z-Wave] Sending command Dim 200 to address 7.
2013/05/25 11:14:33 [Z-Wave] Set value for node 7 and instance 1 to 200
2013/05/25 11:14:48 [Z-Wave] Got value changed notification for node 5 and instance 1 value1 changed to Off.
2013/05/25 11:14:50 [Z-Wave] Got value changed notification for node 7 and instance 1 value1 changed to On.
2013/05/25 11:14:51 [Z-Wave] Got value changed notification for node 7 and instance 1 value1 changed to On.
2013/05/25 11:14:52 [Z-Wave] Got value changed notification for node 7 and instance 1 value1 changed to Dim 239.
2013/05/25 11:14:59 [Z-Wave] Got value changed notification for node 5 and instance 2 value1 changed to Off.
Shutters are not stopet at position command is send...
Any idea ?
U
If i check
Fibaro FGR221 Domotiga Open Zwave help needed
Moderator: RDNZL
- Starting Member
Re: Fibaro FGR221 Domotiga Open Zwave help needed
I think the answer is no.
When setting dimlevel the power wil be 110 Volt (50%) and therefore you will kill your dimmer. However i would try to time the speed of the shutter en than make different events for each level of open/close . Just make an event "ON" sleep 2 seconds " Off" to get it to some kind of half open position
- RDNZL
- Forum Moderator
- Contact:
The dim command doesn't really dim the fgr I think, it's just a way to tell domotiga to send a command to zwave.
I will try to find my fibaro shutter module and do some tests...
Regards, Ron.
- Starting Member
HEllo,
thank you for help.
How to make such an event?
I know how to make event from on to off at specific time but how to make event from on to off with 6s delay at specific time?
U
thank you for help.
U
raymonvdm & rdnzl are correct, it isn't a "real" dimmer device. I personally find this is a "bug" in the Z-Wave implementation (also possible Fibaro ignores it). You can do an "on" and quickly an "off", but no guarantee what the position.
@ birdhouse99:
This week i will submit an updated wrapper, which should support the Dim command for your FGR221.
It is confirmed to be fixed in revision 1328 of DomotiGa by a Fibaro FGR221 user.
