I have a SC9000 station, when I register MS90 (I bought also another one), after a while, when it detects a movement, on the station TAMPER alarm appears and I'm not able to clear it, if I don't clear the zone itself.
What can I do?
Where I'm wrong?
Thanks
Marmitek MS90 sensor and SC9000: always TAMPER alarm
- Starting Member
- Starting Member
Re: Marmitek MS90 sensor and SC9000: always TAMPER alarm
No body can help me?
What Can I try?
What Can I try?
The tamper alarm is probably set by a micro switch inside the MS90. The switch detects that the unit is opened. You can open the MS90 and see if the switch is in its normal position.
Han Alink
