Of course, I'm willing to test you solution. I will get the soldering iron again
Sidenote: thanks to http://www.opentherm-gateway.com/ for sending the needed components for the rs232 conversion as a service.
That's not really necessary. I was able to reproduce the issue, so I could also confirm that the fix I had in mind worked. Thanks anyway for the offer.milux wrote:I can test the new version of otmonitor if necessary.
