traffic perl help?
Forum regarding Linux Software and Home Automation Domotica.
traffic perl help?
Postby Snelvuur » Mon Jun 02, 2008 5:48 pm
All,
it seems if you register on http://www.trafficnet.nl/default.asp , you can have a nice indication on the amount of traffic and how long the traffic is.
If you then go to the page again, you dont have to login but you still see the data so i assume it sets a cookie..
This is an example, with the page showing:
Cookie: routenet=guid=%7BB6D12C51%2D9E95%2D4146%2DBFB4%2D039F6E427012%7D; ASPSESSIONIDCCQATDRB=FDEGENNBPIPJCHFADELJIFCP
the GUID is the same as your rss url.
Only when i try to move the cookie from one place to another it does not yet seem to work.. i want to create something simple in perl for this but to no luck yet.
Anybody else feels up to it? , it looked simple in my head..
Snelvuur
traffic perl help?
Postby Mhwlng » Mon Jun 02, 2008 6:01 pm
not an exact solution to your problem,
but I display this list, which does not require a login :
http://www.vid.nl/VI/overzicht
(I also display this one-line rss feed http://www.vid.nl/VI/_rss )
Marcel
Mhwlng
traffic perl help?
Postby Snelvuur » Mon Jun 02, 2008 10:21 pm
Well yes, but you can create your OWN routes, so that you can see on 1 specific route what the amount of traffic is. Which vid does not offer..
For instance, this is my rss link which is without login, but does not show the extra time when there is traffic.. http://www.trafficnet.nl/rss.asp?guid=B ... A3E146705A
which it does once you got the cookie..
Snelvuur
traffic perl help?
Postby Snelvuur » Wed Jun 04, 2008 1:52 pm
This is what i got sofar.. if i'am correct this will rewrite the cookie.. but it hink i'am missing something else too.
If this works i can have a light turned on or something if there is too much traffic on my route :) my routenet guid is included to test with if needed..
#!/usr/bin/perl -w
use LWP::UserAgent;
use HTTP::Request::Common;
use HTTP::Cookies;
use HTML::Parser;
$ua = LWP::UserAgent->new();
$ua->agent("Mozilla/4.0 (compatible; MSIE 5.0; Windows 98; DigExt)");
# get apiid from page
$url = "http://www.trafficnet.nl/";
$resp = $ua->request(GET $url);
die "Can't fetch $url\n" if !$resp->is_success;
# parse cookies
$cookie_jar = HTTP::Cookies->new;
$cookie_jar->extract_cookies($resp);
# add cookie value for roads
my $stripcookie = $cookie_jar->as_string;
$stripcookie =~ /Set-Cookie3:\s(.*)\spath=/;
my $session ="routenet=guid=\%7BB6D12C51%2D9E95%2D4146%2DBFB4%2D039F6E427012%7D\; $1";
print $session;
#$cookie_jar->clear;
$cookie_jar->set_cookie("$session");
# get data from page with cookies and apiid
$url = "http://www.trafficnet.nl/default.asp";
$ua->cookie_jar($cookie_jar);
$doc = $resp->content;
print $doc;
Snelvuur
Return to Linux Forum
cron
