Controller positon on wire
Forum about 1-Wire devices.
Is it possible to put te controller in the middle of the wire or must it be at one end of the wire?
Let me explain this.
I have to position the controller near a 220V junctionbox. From there i need to run a wire of about 5 meter in one direction and 4 meter into the opposite direction.
123unlock
Re: Controller positon on wire
Post by 123unlock »
Hi Bram,
Yes this is possible, make sure the data and gnd are correctly positioned. then it should not matter on what location the controller is.
here i had the same situation, but the controller is the middle works perfect, at least for the DS18Sxx temp sensors
Xtrusion Digital Home Automation Project
Thx for this information
vincenttor
Post by vincenttor »
maybe interesting to read:
http://www.jon00.me.uk/onewireintro.shtml
I used a daisy chain connection also and some resistors to prevent errors,got about 9 sensors connected at my partents house with 1-wire and a arduino
Return to “1-Wire Forum”
