Replacing a 17,5mm DIN module with FGS-211?
Postby slarti » Fri Feb 01, 2013 12:06 pm
I have a car heating post with a 17,5mm DIN timer module, and I was thinking about replacing the timer with an FGS-211. I found out there are empty 17,5mm DIN rail boxes available. I think the FGS-211 could just fit in the box. My concern is that the Fibaro module is not meant for freezing temperatures and I don't know how the antenna will work in such a small box. Has anyone tried to do anything similar?
Does anyone know of a commercial DIN rail zwave module?
The timer module:
slarti
Re: Replacing a 17,5mm DIN module with FGS-211?
Postby mrqnapper » Fri Feb 01, 2013 12:26 pm
Hi, I have two Fibaro switches outside in a closed box. They have been out there since last September and I did not experience any problem with them so far. Temp. have been -15 degrees Celsius over here during that period.
Wiechert.
mrqnapper
Postby slarti » Sat Feb 02, 2013 11:53 am
Thanks! I guess I'll go ahead and order the parts.
slarti
Postby raymonvdm » Tue Feb 05, 2013 5:59 pm
Last week i found a site which is selling din-rail mounting with tape for mounting Fibaro modules
http://www.smartronix.nl/Webwinkel-Prod ... lclip.html
raymonvdm
Postby slarti » Fri Feb 08, 2013 10:11 pm
raymonvdm wrote:Last week i found a site which is selling din-rail mounting with tape for mounting Fibaro modules
Thanks but I needed to mount it like the timer module. I ended up ordering a CMEB enclosure for it.
The module fits in nicely except for the cover. It's approximately 1mm too thick for the enclosure. It will work for my purpose but it isn't perfect.
slarti
Postby nemo136 » Tue Jan 14, 2014 8:51 am
There is a 'workaround' if you need to use multiple fibaro modules. You can buy an extended enclosure with no lateral covers. With your enclosure and the extension, you can fit two modules inside and close the second enclosure, the two modules fit perfectly inside.
nemo136
Postby Bergerie » Mon Apr 27, 2015 10:53 am
Could you advise what slip-on soldering clips you used?
Bergerie
Postby kriz83 » Mon May 11, 2015 9:14 am
slarti wrote:
raymonvdm wrote:The module fits in nicely except for the cover. It's approximately 1mm too thick for the enclosure. It will work for my purpose but it isn't perfect.
From the picture I can't really see what you mean. Could you explain a little bit more ?
kriz83
Postby kriz83 » Mon May 18, 2015 8:06 am
Could you clearify ?
kriz83
Postby vincenttor » Mon May 18, 2015 2:40 pm
he probably mean's that the black unit thats inside the din housing is to thick, hence why you stil see the black unit instead of the cover that closes the din unit.
vincenttor
Return to Z-Wave Forum
cron
