Would it be possible to let the 'command' page display output of the PS=1 command?
Now it doesn't work when i call http://localhost:8080/command?PS=1
It shows the output of PS=1 in the otmonitor log, but unfortunately not in the webpage output, it only shows PS=1 again....
When showing the output from PS=1 also on the webpage output, i could scrape the contents much easier with something like a PHP-script and store it in my own application stuff. For now the only option seems to be to open a socket to the OTGW directly, which is much more work and quite difficult, especially when the OTGW is connected to a different physical machine.
Please add this option if possible
Please add output of PS=1 to otmonitor webpage
Re: Please add output of PS=1 to otmonitor webpage
I'm not sure it shows the info you want....but maybe you can use the json output?
http://<ip>:<port>/json
That's perfect, thank you very much!timoline wrote:I'm not sure it shows the info you want....but maybe you can use the json output?
Too bad that such things are not documented at all @ the official website... would have saved quite some time if i found this out earlier.
Agreed, the documentation at the web site is horrible and incomplete. I might just as well shut it down.
yes please shut it down...it's rubbish...
Ok,now serious....you did/do an amazing job by making this all possible, great great great respect
