MQTT to Graphite to Grafana
Forum about MQTT, machine-to-machine (M2M), "Internet of Things" and Node.js
Moderators: Digit, Rene, Willem4ever, Bwired
Postby raymonvdm » Thu Dec 03, 2015 11:41 pm
In the past i have used Cacti as a way to log my historical data from my domotica devices. There was a script which pulled data from the MySQL database of Domotiga and created the graphs in Cacti (eventually) but after a change from Domotiga -> HS2 -> OpenHAB -> HS2 -> HS3 -> OpenHAB -> HS3 (for now) the database graph creation was lost.
Until this week and i will use this topic to describe the steps i have taken to get things going.
At first i needed to get the data out of HS3 into something i could use on other platforms. Since many of the domotica software is now talking MQTT (in some sort of way) i first installed an MQTT Broker
Installing an MQTT broker on a Ubuntu 14.04 LTS server
sudo add-apt-repository ppa:mosquitto-dev/mosquitto-ppa
apt-get install mosquitto mosquitto-clients python-mosquitto
And made some changes to /etc/mosquitto/conf.d/local.conf
Install the HS3 MQTT Plugin
Now to get the data onto the broker i installed the MQTT Plugin created by Geert-Jan and configured it to send some sensor data to the broker we just installed on the Ubuntu Server
Since there is data available on the broker we need to get it out to something usable. I planned to use cacti for this and i found a python script created by JPMens called MQTTwarn the export to cacti failed because my input file could only hold one value but MQTTwarn is updating the file with each value on a new line in the file so i have suspended the log to file project for the moment. But taking another look in the features of MQTTwarn i found out that it is also capable of sending "carbon" output and although i heard that name before it took me a day to realize that it was used by Graphite as an input source
Send the MQTT data to carbon
[defaults]
hostname  = '192.168.1.200'
port      = 1883
; name the service providers you will be using.
launch   = file, log, carbon
[config:file]
append_newline = True
targets = {
    'f01'       : ['/tmp/f.01'],
    'douchet'    : ['/etc/snmp/douchet.txt'],
    'douchev'    : ['/etc/snmp/douchev.txt'],
    'kantoort'    : ['/etc/snmp/kantoort.txt'],
    'kantoorv'    : ['/etc/snmp/kantoorv.txt'],
    'slaapkamert'    : ['/etc/snmp/slaapkamert.txt'],
    'slaapkamerv'    : ['/etc/snmp/slaapkamerv.txt'],
    'woonkamert'    : ['/etc/snmp/woonkamert.txt'],
    'woonkamerv'    : ['/etc/snmp/woonkamerv.txt'],
    'buitent'    : ['/etc/snmp/buitent.txt'],
    'buitenv'    : ['/etc/snmp/buitenv.txt'],
    'mqttwarn'  : ['/tmp/mqttwarn.err'],
[config:log]
targets = {
    'info'   : [ 'info' ]
[config:carbon]
targets = {
        'c1' : [ '192.168.1.198',2003 ],
topic = #
targets = file:f01
[/homeseer/398/value]
topic = /homeseer/398/value
targets = file:douchet,carbon:c1
[/homeseer/400/value]
topic = /homeseer/400/value
targets = file:douchev,carbon:c1
[/homeseer/402/value]
topic = /homeseer/402/value
targets = file:kantoort,carbon:c1
[/homeseer/403/value]
topic = /homeseer/403/value
targets = file:kantoorv,carbon:c1
[/homeseer/405/value]
topic = /homeseer/405/value
targets = file:slaapkamert,carbon:c1
[/homeseer/409/value]
topic = /homeseer/409/value
targets = file:slaapkamerv,carbon:c1
[/homeseer/413/value]
topic = /homeseer/413/value
targets = file:woonkamert,carbon:c1
[/homeseer/415/value]
topic = /homeseer/415/value
targets = file:woonkamerv,carbon:c1
targets = file:buitent,carbon:c1
[/homeseer/397/value]
topic = /homeseer/397/value
targets = file:buitenv,carbon:c1
[/homeseer/#]
topic = /homeseer/#
targets = carbon:c1
After we start python mqttwarn.py the carbon messages are sent upon reception of an MQTTmessage :D
The Grafite / Grafana Part
This is a little teaser to show the potential of Grafana
And here is a little how to install Graphite / Grafana
Note: I will update this topic as soon as i have some historical data and a second install run
raymonvdm
Re: MQTT to Graphite to Grafana
Postby Bwired » Fri Dec 04, 2015 12:34 am
nice thanks sofar!
Postby raymonvdm » Fri Dec 04, 2015 11:26 am
I also received an update of JPmens
have implemented code for this with the overwrite parameter:
[config:file]
overwrite = True
targets = {
   'mylog'     : ['/tmp/mqtt.log'],
raymonvdm
Postby raymonvdm » Fri Dec 04, 2015 10:10 pm
Is there someone who can help me out to understand the data which is send to MQTT / CARBON. For example when i look in the file that is logged from temperature the temperature is noted as 19,50 but i think both Grafana and Cacti need 19.50
This value is used by RFXcom Temp sensors but i`m also using a Fibare 1-Wire sensor. Is this the result of a dutch language setting in Windows 7 or is it HS3 related (and changeable?)
I just changed this setting on the Windows 7 machine running HS3
Start -> Control Panel -> Region and Language -> Formats -> Additional settings -> Decimal Symbol changed from , to .
raymonvdm
Postby raymonvdm » Thu Mar 01, 2018 1:02 pm
For Windows 10 you need to change this using
Start -> Control Panel -> Time and Language -> Formats -> Additional date, time & regional settings -> Region -> Change data, time, or number formats -> Additional settings -> Numbers -> Decimal Symbol changed from , to .
Note: In mij case this seem to have caused issues with the JowiHue plugin which cannot see the lights anymore, so maybe a different aprouch is needed
So i`m trying to translate 16,3 to 16.3 using MQTTwarn
I have modified mqttwarn.ini
[defaults]
hostname  = 'mqtt.test.nl'
port      = 1883
username  = mqttwarn
password  = Sadsc
clientid     = 'mqttwarn'
functions = functions.py
[/homeseer/#]
topic = /homeseer/#
format = replace_comma()
targets = carbon:c1
and created a functions.py
def replace_comma(data):
    if type(data) == dict and ',' in data:
            return "."
    return None
It is not working yet, but this seems to have something to do with the dict
raymonvdm
Return to MQTT & Node.js
cron
